Bull Run ride
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I'm not sure if it's safe to do the pioneer but on trucks that I wanted to disconnect power and hopefully try to reset a computer, I would take both battery cables off the battery and touch them together which would instantly drain any residual power in the system versus leaving it overnight.
The smell thing has me worried. That's what don't make sense.
I think I mentioned this but when I started it last time and it ran perfect, the smoke had no odor whatsoever. I think it was vapor due to how fast it dissipated. Couldn't feel anything warm. Gently bent any wires I could see (great way to tell if any are burnt inside their insulation. Wire will be stiff where it's burnt). Still thinking some current jumped a small gap from a plug not totally tight. Moisture was probably making the connection.
Manwell
Manwell
803
2,440
@drfubar are you up for some synchronized donutting? Gotta admit that would look pretty cool lol. Wow we gotta get to the trails soon. Being bored is not good!
Uhmmm, yes you need to get to the trails immediately!! Lot of fuel, clear your mind, breath the fresh air, spend the entire day in the woods, try to not think about going around in circles... Your comment about the "synchronized donutting" (is that even a real word?) is quite worrisome!! LOL
drfubar
drfubar
TheDonFather
5,889
19,242
Mary's Ridge (Dayton Mtn), TN
It was fun but I had not only mud to get off the Honda but there was grass clogging everything. Hanging on to everything too. I had to get in there and pull it out. The washer would not blow it out... IT's now mud down there but it was originally grass
Delton what time are you going to be tackling your 1000 ?
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I was lucky and didnt have to deal with grass. It seems to bond the mud together and make cleanup even harder as you mentioned. Honestly it was way more trouble cleaning than it was worth. But hey, it involved mud, my beloved machine, and high rpms right?
Which part? Troubleshooting, drying connectors and greasing, or continuing on the rear bumper build?
Well I guess all but I'm more concerned about you not having more problems. Was wondering if it started fine no hiccups and all that this morning
Reactions: DGann and drfubar
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Oh ok lol. I'll go out there in little bit. Only got 1 of 3 kids enrolled in school so I'm kinda stuck inside with the 2 brothers. They seem like good kids so I'll sneak off in little bit and at least see if it'll start.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
There's very few electrical connectors in that area so shouldn't be too hard to cover all of them. O2 sensor is the most obvious. Now if the smoke/vapor was under the hood, then I'd be worried lol
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I'll spare y'all the step by step and cut to the chase. It started. Still had little smoke. Found some wiring in a bind against my HL lift bracket. Loosened wiring and rerouted around bracket. Now runs with no smoke. Still plan to grease everything and need to inspect wiring for breaks in insulation.
IMG 20161207 102011519 1336x752
IMG 20161207 102057864 1336x752
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
It looks obvious that the wiring is in a bind, but those pics were taken with me bent up like a pretzel to get a clear shot. Wiring is actually hidden by frame rail so I had no idea the lift was interfering with the wiring.
View attachment 27948 View attachment 27949
That's great news! Electrical problems is a nightmare but if you found the cause all good I'm sure you'll rest easier. Thanks for the update I'll look at mine too you may have saved people a hassle here
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Yeah I forgot you have same lift. Rear bracket has a slot cut in it that fits into the frame. When you push bracket into place, it hits the wiring and puts pressure on it. Take a screwdriver and pop out the holddown from the frame. That'll give you a little breathing room.
Manwell
Manwell
803
2,440
I will be taking a close look at mine as well! Just like I dielectric grease everything I run across, I also wire tie the crap out of stuff. I get it that they can't do it all during the production of the machine, but I have the time to be picky! Wires giggling around just isn't a good thing in my opinion!
I'll be looking tonight! And thanks for the good info on the lift when I was researching. I really like it and agree on stability.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
These weren't jiggling from the factory. They actually did a great job of securing them to the frame. And that was my problem. When I slid the bracket in there, there just wasn't any slack in wiring to accommodate. Totally user fault. Hoping that's all it is.
