P1000 Bussmann fuse panel relay issues
You are correct... I can’t be much help I don’t guess.
Nah you’re usually a lot of help with this stuff
Reactions: sharp
RedFred1
RedFred1
301
619
North Carolina
Does yours look like this on the back?
Back of bussman box
If so, it should not be hard to find it using your ohm meter and a wire probe or paper clip to search the fuse holders or relay block terminals.
The site has a good selection of pictures.
Concours Specialties
FredD
Reactions: Remington
OnTheJob
OnTheJob
426
925
Bristol, NY
The Bodenzord write up covers everything you should need in excess detail. I really like reading it when looking at options for my fuse/relay box and the accessories that I have on my machine.
Wow that guy is good. Something to aspire to on the next build. Wire it ALL at the same.
Reactions: ToddACimer
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,230
Oshkosh, Wi
That's the awesome part. Super clean install and easy to add more components as you go.
OnTheJob
OnTheJob
426
925
Bristol, NY
Right. Even if you didn't know what that switch/circuit/relay was going to be it has a plug ready to go when you decide later. He's using half the wires I would use to the dash switches in one 6 wire harness. Very clean.
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,230
Oshkosh, Wi
Right. Even if you didn't know what that switch/circuit/relay was going to be it has a plug ready to go when you decide later. Very clean.
Only bummer is running out of switches. Im full now but short one switch. I have a few double switches now. Up will be fan on down will be interior lights in first one. I don't expect to add much more but I might get another panel made without the volt meter.
IMG 20190124 190932
Reactions: JTW and OnTheJob
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,230
Oshkosh, Wi
That's some smart thinking there. I could not imagine trying to explain that to most.
Not everything needs to be on at the same time so it should work out. My alternative would be keep the interior light switch and put the switched ground for the reverse light opposite the fan. I'm probably one of the few that have a switched ground on the dash but I'm excited to have reverse lights and rear lights with my diode arrangement
Reactions: BWAF and JTW
Neohio
Neohio
Beast of the East
21,739
93,107
Painesville Ohio
You might be able to add another switch to your current plate if you use the plastic mounts they sell. Usually lets you get the switches closer together.
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,230
Oshkosh, Wi
I'd have to cut out all the switch holes but I did consider that
Reactions: BWAF
116,567
FredD
Thanks Fred. Yes mine does look similar to that. Was going to take it out and check it but the way I have it mounted was a pain in the arce to remove it and with everything Else I have going on under the hood. I ordered some new relays and I’ll just switch them out and keep the old ones for emergencies. If that ends up being my only option,I’ll just have to take it out to Check.
