P1000 Buying 2024 pioneer.
Craig1982
6
Illinois
  1. Looking to buy
  2. 1000-3
Going to be purchasing a 2024 Honda Pioneer 1000-3 in a few weeks. Trying to decide what the best route is to do a dual battery system with 2 winch front and rear light bars in front and the rear. Do you guys recommend to use the factory fuse box or to go aftermarket?
StewB
StewB
715
3,305
Winch contactors/solenoids should run direct off a battery with the provided inline fuse.
Set up a relay and aftermarket fuse block - there are lots of descriptions on the site.
With your initial plan, use a minimum 12 post aftermarket fuse block or you'll regret it like I still do.
Dump the other inline fuses and use the proper amp rated fuses in the block.
There are a lot of great guides and thoughts on this site. Use the search bar.
Good luck.
114,461
Welcome from Michigan.
When u pick it up, dont forget to post pics of it asap! These guys are relentless if you dont!
POIDH.
If your running a winch front and rear, deff a dual battery is needed. These rigs are voltage sensitive and its best to keep the accessories on there own battery and the main for OEM stuff as much as possible. Id recommend a separate fuse/ switch panel like Auxbeam (simplest) To power that stuff up.
Check out the club store from the drop down at the top of the page and get your stuff. We like to support this forum to keep it going.
