P1000 Cab heat issues
Stalkman50
14
37
I just put a deposit on a 520 thinking about going back and getting the 1000-5 simply because of top end speed. Is the Cab Heat Issue too much to handle? Ill have kids with me and want something that they can ride in too. Id wayy rather have the 1000 but did not pick it simply because of this issue. Is it tolerable and just an annoyance or is it unbearable?
208,726
In the Summer yes, but there's a simple cost effective method, put a fan under the seat blowing on the header with switch on the dash. Heat in the winter and tolerable in the Summer. There are threads on the different methods here.
WagginTail
WagginTail
1,582
5,862
SC
Like Smitty said put a fan under the seat. I'm getting ready to do that to mine. Also you can get a trigger shield to help out. Last thing is to have the windshield open when it's hot out.
Vikes79
Vikes79
SKOL!
11,712
113,628
South Dakota
  2. Talon X4 LV
Down south maybe it’s a longer term issue, but up north the window of time per year that it’s a concern is much smaller.
A good bilge fan and some carpet scraps works good for my kiddos.
oh yeah, go with a SATV window or a front screen….that solves big heat retention. I personally use a Rouge power screen in the summer in my rig.
Y
Yakman
127
314
WA
I'm with the others that say go with the fan under seat. I put a bilge blower under mine pointed right at the exhaust heater. I can feel the seat start cooling off as soon as I turn it on.
Ridinfool
Ridinfool
36,144
386,046
Western North Carolina
What these guys 👆👆👆👆said. Is cab heat an issue on these? Yes. cab heat is an issue on ALL SXSs basically you are sitting on the motor, the under seat fan along with the trigger shield (send a pm to @trigger ) will make a big difference. Also, if your kids are riding with you, you’ll definitely want the P1K. Good luck on your choice and remember Pics Or It Didn’t Happen.
208,726
Well said!
115,790
Well said!
Ditto!
MrTidd
10
19
Ohio
I have the same heat issues with my talon the wife complains about it only I the summertime lol but I have to get some sound mat and heat shielding along with sealing up the body openings in the cab
179,021
I make one for the Talon too.
Talon Shield 3
Glank
Glank
100
340
Living in Michigan, I haven't worried about fans or heat shields. We (family of 5) spent two sunny hot July days on the sand dunes and no one complained about heat. Most of the time we're glad to have the extra heat.
O
olfarmer
Does anyone have any luck with improved seat comfort using some of either the breathable or gel seat pads?
Reactions: Lady01
115,790
Nope, found it makes your ass sweat more. Yes more comfy.
Just install a bilge fan under the seat and be done with it.
BTW Welcome from Michigan where we do need a fan in the summer unless you have one cold ass 😂
Congrats on your first post.
#POIDH
Y
Yakman
127
314
WA
#POIDH
I too put a bilge blower under my seat blowing directly at the exhaust header. Cools the seat off instantly.
bumperm
bumperm
1,899
6,778
Gardnerville, NV
Do you find the bilge blower cools it off adequately by itself, or have you also installed under seat/seatback insulation? I've done the blower, but the weather hasn't been hot enough to test it. Haven't gotten around to installing the insulation yet.
Y
Yakman
127
314
WA
I added the under seat/seatback insulation first and hardly noticed a difference. The blower is like night and day. My girlfriend says it cools off instantly when I turn it on. Here's the one I'm using: https://www.amazon.com/gp/product/B001O0DE9E/?tag=sxsweb24-20
and I just made a bracket for it to attach to.
HBarlow
HBarlow
1,627
6,047
Daniels, WV
At crawl speed cab heat is annoying but with a two-piece windshield with upper portion opened slightly and a little air flow provided by road speed it's not an issue.
Reactions: Lady01
bumperm
bumperm
1,899
6,778
Gardnerville, NV
and just I made a bracket for it to attach to.
Thanks you! I'm going to hold off doing the under seat insulation I think. You have to dig through the question/answers on Amaz', but the blower you used is 3" and rated 120 CFM. I used a 4", 270 CFM blower, so hoping that'll do.
Shown with inlet reducer removed - don't do that, it actually reduces flow a bit.
20211213 153122
Y
Yakman
127
314
WA
Should work. You're kicking out over double the CFM of mine. I put mine off to the the passenger side of the engine so it blows directly on the exhaust header. Come summer you'll know if it works :D
