P1000 Cely's 2021 P1K5 Deluxe Build
Y
Yakman
128
315
WA
Half the fun of owning it is customizing to your personal tastes. Looks great! Now go get it dirty ;)
Reactions: Lady01
Cely1932
Cely1932
91
591
83
Loveland, CO
I decided to add the Honda bedliner. I found one on Ebay for $400 shipped. We have a lot of new landscaping coming up at the new house and feel it will be worth it to keep crap out of the seat and door areas. It easily removes with 3 screws.
I suppose the warning label area could be used for more switches.....;)
20220406 080117
20220406 080135
20220406 080150
Added the tailgate leveling brackets from @mystic1219 . These are great brackets. I'm not too fond of the taller versions that are out there. Of course when installing, I discovered that Honda neglected to install one of the 2 bushings on the passenger side so I had to make one.
20220405 090342
I found the largest water tank I could at Tractor Supply that would physically fit as well as be near the Pioneers max weight capacity when full. We have A LOT of new trees that will be planted at the house as well as routine ditch burning that I want to be prepared for. I need to build a frame yet that will mount the tank, pump, ect. in the back. Have I mentioned that I miss my welder....
20220331 105018
20220406 081221
20220406 075855
20220406 081454
I spent what seemed like forever deciding on a phone mount location. I finally decided on the ROPS above the driver. It's out of the windshield viewing area and shouldn't be affected by the suns glare, and yes, It's out of the way of the rifle when locked for travel or swung down to be deployed.
20220406 080321
20220406 080400
20220406 080417
20220406 080453
20220406 080538
This, of course, required an additional USB charging port within reach of the cable......
20220406 080736
20220406 080753
Cely1932
Cely1932
91
591
83
Loveland, CO
It's been a while since I've been able to do much on the Pioneer. I finally made the Delrin mounting plates for the Rough Country rock lights I bought to use as dome lights and cargo lights. The two front lights are mounted on the upper angled portion of the ROPS, just behind our heads. I machined a radius in the back of the pad to match the bar diameter and basically glued it to the bar with Permatex Ultra Black. The cargo lights are slightly angled and attached to the roof with 3M tape. Had to clean the crap out of the roof to get the mold release or whatever the heck was on it, off, in order to feel good about the adhesion. These things are quite bright, and do an excellent job!
20220524 082250
20220524 105004
20220603 103211
20220603 103224
ToddACimer
ToddACimer
Pioneer 1005-2
3,793
16,080
Oshkosh, Wi
Those look really good.
Similar threads
Replies
Views
370
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
3K
