P1000 Center Seat Belt?
Sparky74
Anyone remove the Center Seat Seatbelt completely and then move the Passenger & Drivers Seatbelt Buckles to the center seatbelt mounts? Thought this would give a little more hip room for the Driver & Passenger! If you have removed it, how did you disconnect & reroute the wires for the Drivers Buckle? My Honda is a 2017 1000-5.
13,375
65,260
If you are moving the drive buckle over to the center, It should reach. I believe the wiring has enough slack in it to fit in both positions. You may need to remove the plastic shield between the seats bottom and back to reroute the wire. I think it is clipped into the seat frame for routing.
The driver buckle plugs into here. (white plug, bypass installed)
IMG 20190216 1451232
Reactions: Sparky74
Sparky74
Does the White Plug go into the Red Plug? How did you make the By-Pass? By-Passing the thing would be a lot easier & nicer!!
13,375
65,260
The white plug connects to the seatbelt.
The red plug is the diagnostic jumper for getting codes on the dash. I put the loop of the bypass around it to keep it from hanging down.
The bypass was installed because the owner wanted harnesses installed. Unplugging it would have limited the machine to 15mph. Which would have been funny, but not a phone call I would want to answer.
I'll look thru my emails to see where I got it.
Reactions: CPope and Sparky74
Sparky74
Thanks for the info. I would like to By-Pass the whole thing if possible and not have to mess around trying to reroute the wires! Will be awaiting to hear any info you can find on where to get one of those By-Passes.
Reactions: CPope
13,375
65,260
Not a problem, i'll search around my emails.
13,375
65,260
Harness accessory seatbelt bypass kit
I made my own. But found this in our club store at a reasonable price.
Sparky74
Neohio: I removed the Center Seat Belt and moved the Driver & Passenger buckles to the center mounting locations, Also installed the By-Pass plug you mentioned (your pic really helped!) and everything works great! Moving the buckles inwards does give the 2 front seats a little more hip room and comfort. Thanks again for the tip on the By-Pass Plug!
Reactions: Neohio
13,375
65,260
Glad everything is working well for you.
Reactions: Sparky74
