P1000 CFab arms Install Advice
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
Looking for any pointers on doing the install on the cfab a-arms with the lift built in.
will post some pix when i unbox them.
make sure you grease the bolts and put a spacer on each side of the heim joint. are yours coming with the ball joints already installed or are you doing it
perry
perry
191
168
South Dakota
I filled the tube with grease and put some on the inside of the bolt on the top a arms and put the spacer on each side and one washer on the back side of back spacer. Got the front done and will be working on the back soon. Looking good on the front what a difference in the look on the front.
knuckledeep
knuckledeep
1,052
3,470
Eustis florida
post some pics when you get it done
A
Alowery
21
Florida
Did you mean popping?
If you're running stock axles with 3" arm lift, it's a good idea to avoid hard turns in 4wd.
Yes I meant popping and thanks for the info. Basically I needed to relaxe the axles before applying full weight of the vehicle. The problem is now resolved.
chucksmith0706
295
1,102
Louisiana
854bc4ed81ea98c104eaf9a504b9c797
3066d37fcc2f8a061e8131033acca936
91c41e774c1a7ba10b92c0e6819fff6b
Well worth it to me.
