P500 Charging/Jumping Battery under the hood
  • Thread starter Deleted member 3748
  • Start date
162,461
As an Amazon Associate we earn from qualifying purchases.
Deleted member 3748
Very cool, that's the way to do it right there. Question is, do you wire all the way back to the battery? There was a 2 ft adapter, that was suggested with the socket, that has ring terminals on it. Could I wire that to my winch solenoid instead?
Connecting to your winch solenoid is what started this thread. Though I have a circuit breaker before the solenoid that I used. My ground is a bus bar bolted to the frame
Reactions: rocmar and trigger
162,461
Then the solenoid connections are considered "heavy duty"? Because some guys have a dual battery set up and fuse blocks under the hood...
just asking for more specifics Piston. ;)
rocmar
rocmar
4,741
5,775
4 CORNERS
My buddy run stuff off the
winch...& had a dead battery
if he let it sit....2 days
34,175
Some people do that trigger. But the proper way would be to run a 6 gauge hot wire from your battery, circuit protected in the battery box (100 amp) to something like a four or six position Sea Ray under the hood with a buss bar for ground on the frame (like Piston mentioned) and then you can run electronics through the dash from that with your smaller (12, 14, 16 gauge) wiring all fuse protected by the blade fuses in the Blue Sea Ray.
hoggr9
88
Xenia, IL
I wired my socket to my winch contactor under the hood..
This was for my battery tender.
162,461
@hoggr9 's way sounds a lot easier monte. ;)
Deleted member 3748
Haha, it's all in the wording. You already have your winch cable under the hood. That becomes the cable that connects to your Blue Sea Ray fuse panel or in my case a 100 AMP circuit breaker. Then you connect all of your electrical crap to that instead of the battery, and as a bonus, you can charge your battery from there.
162,461
I have fused power blocks mounted in the toolbox already. I'm not saying it's too difficult intellectually, financially...why go through all that to hook up a tender? Could put the socket on the box? o_O
34,175
Clean safe future expansion was what prompted my earliest comment to you. But if you think you'll never add any other electronics after this tender than take it off the contactor.
rocmar
rocmar
4,741
5,775
4 CORNERS
Going off winch contacter....
removes the cicuit protection
& the guys I know that went
that way...had a dead battery
in 2 days...
just sayin
Deleted member 3748
I don't know why we do half the things we do to our Hondas.
162,461
Deleted member 3748
Ordered one of these just now. Ordered the pig tail with ring connectors too.
Thanks for sharing that and I'll post pics when installed.
I don't know what this is yet, but the odds of me buying it after clicking the link are pretty good.
34,175
Here's a better picture of it. This is best run directly to the battery, fuse protected. Mine was easy because I ran it straight to the dual battery under the hood, heat shrink the connection between the SAE plug lead and the pig tail.
