So I finally installed some back up lights for plowing my road and drive way. Parts for build, I used napa par 36 4" work lights $12.50 each. Fog light relay harness kit with switch $26. Four feet of wire loom. Two butt connectors. I think they work great. No volt meter to test load yet.
You can tap the gear shift sensor wires near the right rear tire. There you will find a wire that will GROUND when in reverse. You could use that for a relay.
I'll try to get pictures tomorrow or Tuesday of the location.
