Cheap back up lights/work lights
rallymachine
9
0
0
So I finally installed some back up lights for plowing my road and drive way. Parts for build, I used napa par 36 4" work lights $12.50 each. Fog light relay harness kit with switch $26. Four feet of wire loom. Two butt connectors. I think they work great. No volt meter to test load yet.
IMG 12361
IMG 12351
IMG 12341
IMG 12331
IMG 12311
rallymachine
9
0
0
Not yet. I'm looking into that next.
64,680
You can tap the gear shift sensor wires near the right rear tire. There you will find a wire that will GROUND when in reverse. You could use that for a relay.
I'll try to get pictures tomorrow or Tuesday of the location.
bellmichael8683
0
US
Questions : (1)What gauge wire? (2) relay part number?
Sent from my SAMSUNG-SM-T337A using Tapatalk
Ratchetdan
Ratchetdan
29
26
Alaska
@Hondasxs, did you ever find the wire to tap into? I'm interested in tapping my rear LEDs into it.
