Club GMRS privacy codes
Joe_none
60
224
NC
I've searched the forums and found the club channel list but I have not found if we are using any privacy codes (CTCSS or DCS). Can anyone point me to the information or are they not being used?
107,279
Joe_none
60
224
NC
So we don't have to hear other people on the same channel
Selecting a Privacy Code
Continuous Tone Coded Squelch System (CTCSS) and Digitally Coded
Squelch (DCS) are systems that allow several users to share the same
channel without disturbing each other. When CTCSS or DCS is enabled
for a selected channel, the channel is muted to all incoming signals unless
they carry the correct CTCSS or DCS tone.
When a transmission with the correct tone is received, the mute is
removed and the voice audio can be heard. When the transmission ends
the channel is muted again. Transmissions that do not have the correct
tone are not heard.
107,279
tone are not heard.
Thats above my pay grade!
Someone in that department will be along in the not too distant future to help
JenElio
JenElio
65,013
608,520
Loxahatchee, florida
tone are not heard.
🤨🤔........I just yell out the buggy as loud as I can......🤷‍♂️🤦‍♂️😂
NoMo!!
Vondy
Vondy
1,400
8,963
Houston,OH
None of the groups I have ran with have used privacy codes. Most probably wouldn’t know how to. If to much traffic we just change channels
63,963
This..
Getting everyone to change channels is hard enough, much less applying a PC then hoping they remember how to remove or change it with their next group.
Scoop
Scoop
4,237
15,876
  3. Talon R LV
No, nobody uses GMRS privacy codes. Beyond that, they aren't even private.
Set your radios to the channel and 'privacy code', and you can interact with anyone who also uses that channel and privacy code.
It's not like its encryption or anything.
Joe_none
60
224
NC
Right, it's just to avoid hearing others on the channel that don't have the code. Used mainly when the same channel has a lot of unrelated groups on it to only hear your group.
Having a radio is new to me I wasn't sure how busy the channels will be when we ride up in TN. Wanted to make sure I have everything set up before the next overlanding trip.
Reactions: Scoop and Hondasxs
Scoop
Scoop
4,237
15,876
  3. Talon R LV
Correct.
But many people think using a privacy code (aka PL or private line, QC or quiet code, interference eliminator codes when referring to CTCSS or DCS) will stop others who do not set the same PL from hearing them.
Wrong.
If your group radios ARE using a privacy code, anyone who does NOT set a privacy code CAN still hear you ... you just can't hear THEM.
One of the main reasons why the casual FRS/GMRS radio user folks don't privacy codes is because some radios won't let you set one or the radio has them pre-programmed, and if you have anyone in your group that uses those types of radios, they won't be able to transmit to the rest of the group. They will only hear others.
Listen, but not speak - like some children should be. 😁
If anyone wants a better understanding of CTCSS and DCS, reach out to @Backwoods. He knows a lot about a lot of things. 😆
Backwoods
Backwoods
32,520
333,630
Douglasville ga
Correct.
Wrong.
Not me. Ask @Scoop. He perfected nuclear fusion and the truth about Bigfoot. He also started a club for handicapped gays.
Scoop
Scoop
4,237
15,876
  3. Talon R LV
The nuclear fusion, the theory of relativity, the meaning of life, my theorem for distributive lattices states, and the discovery of copper were things I did in my spare time. Bigfoot was pretty tough, though.
I started it for the money, but I'm not a member. Oh, that reminds me: Your 2023 membership dues are late. When do you plan on sending them in?
Scoop
Scoop
4,237
15,876
  3. Talon R LV
If Scoop were to ask Scoop then Scoop would answer to Scoop and Scoop would respond. It would be like an infinite series of responses from Scoop for eternity.
Just like one of those endless photographs of a camera taking a photograph of a camera taking a picture of a photograph of a camera taking a picture of a photograph of a picture of a camera taking a picture of a photograph ...
