Lady01
Hey... No i did NOT have to use any spacing but I did add the 1 1/2" Spacers on the rear just for the look and to keep the same track width front and rear.Hi there,
Did you have to do any spacing? And I assume you have offset a arms? Thanks
I am using stock A-arms with the tires/wheels mentioned earlier. I do rub a bit on full suspension compression while turning. I have the wheel well cutouts that I will be putting in this spring sometime soon. this should help with tire rub.
