It has been highly recommended to stick to oem recommendations by some people in the know.
Here is how it was explained to me.
The computer (based off the GN4 specs) knows the exact time to engage and disengage the clutches based on (X) temperate of the oil.
If you change this. What happens?
Will it cause the expected velocities to be off?
Will clutch timing be altered due to the mis-calculated specs?
What happens during that split second both clutches are engaged together?
Or that split second they are not?
How much added wear can it handle?
Personally I haven't a clue. But I trust Honda knows best.
I expect year 2 to have solutions.
