They tried I wouldn't take. They say that they have never been able to get clutch reset to work. Very small local shop that's more a outdoor store than a Honda dealer. Dose the reset make a big difference? Thanks
If they cant get an initialization to take then your machine is not going to operate properly.
Infact the display would not show the proper gear if they attempted it without successfully completing the procedure.
There is something wrong in there, if done properly a clutch initialization will work everytime. They probably nicked one of the sealing rings. I always use an oil/grease mixture to hold them down when installing the clutch.
Are they installing the entire clutch as an assembly or just replacing the fibers and plates? Because you cant get the proper clearance without replacing the assembly including the basket as a whole. Honda won't even let you order the parts separate for that reason.
Id take it to another place, those guys have no idea what their doing.
