Calendar Coalmont ride [Jun 23, 2018] (Coalmont, TN)
Yankee
Yankee
280
723
Tennessee
KIMG0569
this is one of the few pics I got
Yankee
Yankee
280
723
Tennessee
KIMG0567
@SundayRdr s broke r/f upper a arm mount that broke the weld right down the center. When we were messing with repairs Sunday we did the left side as well and discovered that weld was split down the center too
39,079
View attachment 81188 @SundayRdr s broke r/f upper a arm mount that broke the weld right down the center. When we were messing with repairs Sunday we did the left side as well and discovered that weld was split down the center too
I think they all will do it soon enough. I welded mine plus two more p700’s.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
U would think they would b stouter disappointing really to say the least u would think they were stouter than that
I agree. To me, the design looks like it's be stronger than the 1000 setup
Reactions: Yankee
Yankee
Yankee
280
723
Tennessee
Possibly too much heat when welded? The weld looked good. From what I've been told a weld is supposed to be half as wide or thick (cant remember) as the metal is thick and I saw no under cut enough to hurt anything. May have been enough weld on a colder setting but idk. The thin stuff the frames r made from on any sxs only gives so much that can b burnt into without burning into it too much before burning through and then ur breaking the frame itself instead of the weld
39,079
My guess is a lot of us push our vehicles beyond the design limits and sometimes we find out weaknesses but in a case like this it could be an intentional weakness designed as a crumple zone for head on collision.
SundayRdr
SundayRdr
575
1,179
McMinville Tn
Yea I owe @Delton plenty!!!!!! Hero of the day he is. Everyone was more than helpful on getting lil blue patched up and back to the trailer. Like @Yankee said the lh side was broken beneath the powder coating. 20180715 102413I'm guessing Honda used chinese welding wire. She's braced and as soon as I align the front end up we're having redemption. Oyea and finish my home made rear mudbusters.
SundayRdr
SundayRdr
575
1,179
McMinville Tn
A BFH helped a bunch along with ratchet straps. The frame never will be the same. It twisted the bracket when it finally broke loose. I didn't get a good before picture of it broken loose. 2/3 are after I beat it with a hammer and then after I used a ratchet strap and beat on it some more. It was pretty close once we done the finishing repairs.
FB IMG 1531691298844 20180714 105031 20180714 105046
Yankee
Yankee
280
723
Tennessee
View attachment 81208 View attachment 81209 View attachment 81210
U weren't used to handling a big pecker like that were u lol
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
In all fairness, I did run headon into a 3' mud wall lmao. My weld held fine, it was the actual metal that ripped. I promise you I'll have my passenger side beefed up before we try Hells Canyon
SundayRdr
SundayRdr
575
1,179
McMinville Tn
Chad is there room up there to install a boxed in K frame type section? Probably not but is a good idea.
I'd say you could install one between the front and rear mount. I was considering tieing the front and rear control arm mounts together but we just added braces to the rear control arm mounts on both sides.
Reactions: Yankee and sharp
39,079
Yep, Delton is one of a kind. He's the guy to have with ya if you break.
What do we do if Delton breaks?! Are we all stranded? I guess we just watch him fix his own. Haha
Just kidding Delton, you and Knuckledeep need to make a mobile SXS repair rig company! He’s already got the tow rig down
