P500 Coldest temps for cold engine start up?
Coldest temp for cold engine start (and did you ride)
  • +5 degrees F
    Votes: 9 22.0%
  • 0
    Votes: 3 7.3%
  • -5
    Votes: 2 4.9%
  • -10
    Votes: 3 7.3%
  • -15
    Votes: 6 14.6%
  • -20
    Votes: 7 17.1%
  • -25
    Votes: 2 4.9%
  • -30
    Votes: 4 9.8%
  • - get back in house
    Votes: 5 12.2%
  • Total voters
    41
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,500
Coldest start. Didn’t have to ride, but would be interesting comment if you did. (One for @PistonHonda)
HUCK
HUCK
1,047
2,319
ARIZONA
You need to raise the temp to+20 for me . Of course I rode , why would I start it otherwise ?
I
iceboundzeke
26
26
Iowa
Started so hard I had to use a jumper box to get it running. Is there a different motor oil for winter activities?
Russ989
Russ989
22,642
147,257
It started just fine at -15 and I did ride a few miles, but I must admit it was only because I had to feed and water cattle and check fence otherwise I’d be on the inside looking out lol.
Reactions: R-Lamm
Travissf
Travissf
52
133
Minnesota
-25 was a no go for me, mine started at -20 while in an unheated garage on a battery tender.
Mandryk
Mandryk
21
Ontario, Canada
While on a battery tender in an unheated garage mine started at -30F on the second try.
I rode for an hour dragging trails with a cold smile!
E
elkguide
3,377
7,964
Vermont
-20 here. Didn't stay out riding very long though.
(definitely have to take the seat heat shield out!)
Reactions: R-Lamm
Russ989
Russ989
22,642
147,257
If it were air cooled I’d say change oil weight but it’s liquid cooled so I don’t know that it would give you that much advantage. You could try I 5w30, not sure if it would be worth changing your oil though, it should warm up a touch soon.
R-Lamm
R-Lamm
315
242
South Carolina
That sounds more like battery than oil...batteries do not like it when it is that cold!
I
iceboundzeke
26
26
Iowa
Today I was looking for a battery with a higher CCA but no luck yet.
JollyJoker
JollyJoker
92
192
Minnesota
I just replaced my battery 2 week ago. It was only 2 years old. Mine would crank the motor but the voltage would drop too far and not start. I looked at every website I could and could not find a bigger battery (AH or CCA). I replaced it with one from Batterymart And it has started like a champ even when it was -15 out at the fish house. If you don't use the same OEM battery you have to "flatten" the connectors on the ends of the cables.
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
-5 start and ride, windshield, doors, and rear window. Ride was much warmer than my treestand.
Reactions: Russ989
Seg
Seg
189
322
Notre-Dame de la Salette, Qc, Canada
-30 in unheated garage and battery tender. let it idle for 3-4 minutes then drove up and down lane way slowly to get the gear oil going before starting to plow...Oh, I also remove the heat mat from under the seat!!!
Russ989
Russ989
22,642
147,257
Do you have the Honda doors or aftermarket? I’m on the fence about buying a set.
906UP
906UP
14,405
136,869
da Yoop
-15f when I started it, had been -25f that morning. It's parked in my neighbors unheated pole barn. Just wanted to see if it'd start, it did just like summer. I let it idle for 20 mins or so, temp was up to 2 bars then I shut it down. Didn't ride, that's what the SkiDoos are for ;)
Reactions: trigger
Russ989
Russ989
22,642
147,257
honda doors, found a used set on here for a great deal.
That’s a good deal, are they worth it? They are the only thing I need to have my cab enclosed. Any pros or cons? Durability? Thanks for the info.
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
they are very well made with heavy fabric and windows, a little cumbersome to take on and off until you get the hang of it. I have been bow hunting a lot the past couple weeks and the doors were a lifesaver getting to and from the stand, temps were -5 to 12 above.
Are they work what Honda wants for them I don't know but I do love them, I got mine used for $175. For sure worth what I paid for them.
Russ989
Russ989
22,642
147,257
Well I guess I’m going to start hunting for a set, if I can’t find a good used set, I’ll bite the bullet and buy new. Thanks for the info, much appreciated.
