P1000 Coolant leak
Johnny5isalive
Iowa
Hello! I have been trying to figure this one out. It is right above the oil drain but looks like coolant. I have the infernal heater installed at dealer but it does not look like the hose clamps are leaking. This has left a spot like this every time I ride.
150 miles. Thanks All!! 72185224432  A066771F 5512 4371 9016 E55E2B107334IMG 8658IMG 8659
DRZRon1
DRZRon1
1,206
3,896
PA
That sucks….
Looks like ya got 2 choices - look for the leak and correct yourself - or take back to dealer and tell em to fix it right - you did use hard earned money not to have the machine dripping on your nice floor.
Thanks for posting pics - that’s awesome and nice ride.
Johnny5isalive
Iowa
Thanks! Yea it sucks thought it would be an easy find and fix but looked and looked and have not found yet. 😀
That sucks….
Reactions: Biteme and Hawk53
5,425
24,913
Dealer is replacing water pump anyone have this issue this soon (150 miles)?
Other than another water pump question about a week ago, those are the only two I've seen anywhere in almost 4 years. Last week's question didn't get an answer IIRC.
Reactions: Biteme
DRZRon1
DRZRon1
1,206
3,896
PA
you don’t get it - if customer comes in with new machine, the hose clamp that’s hard to get to is loose, may as well swap water pump and get some warranty kickback bucks- lol 😂
  • Sad
Reactions: CID and JenElio
5,425
24,913
@prostreet66mustang started a thread on his water pump failure/replacement -
Johnny5isalive
Iowa
😀. I had about 4 hours on and off my lift, triple checked all the hose clamps. And I do trust this dealer been good to me, not other dealers but I do this one 😂
Reactions: CID
115,707
The coolant leak comes out by the oil drain. I guess there is a drain hose or a weep hole above that had coolant on it.
Mmmmmm sound like a throw a dart at it and hope to me! Typical FJB mentality for them.
Reactions: Jerryg
Johnny5isalive
Iowa
Well water pump was replaced and then there's this..... I drove it for about an hour and put on lift and looked for an hour for any leaks and nothing. Woke up next day and like magic.... coolant. checked ever clamp/hose. Any help?? Losing my mind 😀
IMG 8809
  • Sad
Reactions: Jerryg and CID
NewHere2
NewHere2
Village Idiot In Training
41,894
345,172
High Plains of SD
Sure it wasn’t residual coolant stuck somewhere after they changed the pump ? Might have vibrated or ran to a place it could drain out while parked ??
Reactions: Johnny5isalive
