P1000 Cover for shifter holes
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
When you have to be different. :)
I used silicone to glue it to the dash.
0829172019
Montana
800
322
Interesting. I hope it holds for you. Thanks Larry
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
https://www.amazon.com/Spectre-Performance-6284-Large-Shift/dp/B00062ZI2W/?tag=sxsweb24-20
i was thinking along these lines, i could use this maybe even put it on the inside of the dash so that you cant really see it.
I like thinking out side of the box, but in this case I would recommend buying Montana's block off plate as it is nicely done.
I thought the rubber would stay better pinched between the dash and the shifter then the aluminum plate.
The Amazon link shows a surface mount boot there is no clearance to mount it on the under side of the dash.
Reactions: JTW and Smitty335
I agree.. I looked at doing some different options but his just works so well and looks great!
Reactions: GPR1500SC
Montana
800
322
I think the 2017 have the heat issues
Covered for the shifters. I do think this cover will fit but I not think you need it.
Thanks Larry
Reactions: JTW
dewitt
Hattiesburg, Ms
Larry, I have had 3 or 4 long rides since installing this fix and I am very happy with it. Honda should have thought of this in the design phase. thanks for the your solution, I also plan on having their shield installed to prevent the dash from getting so hot. so both should fully handle the dash heat issue. Yours was money well spent
Reactions: JTW and joeymt33
Montana
800
322
Montana
800
322
Robert. I recieved you check today
Thanks. Larry
Montana
800
322
I have one cover left if anyone is interested
E
Erick
35
24
Rochester
Montanna - I installed your cover and it works very well at reducing the heat coming from the shifter holes. Thanks.
Montana
800
322
Erick. Glad you like it
Thanks Larry
