P1000 Cover for shifter holes
Bobby_BAS
Bobby_BAS
141
Stearns, KY
Following as well. Now that I have a windshield, I realize the crazy amount of heat that comes out through there...
Reactions: sharp
Cecilspears89
Cecilspears89
9
15
Saint augustine, Florida
X2 on pics. Where is it located?
77253ffa8e7516a826f127da4b5a328a it's a lot of work. Started when I wanted to mount the winch high. I couldn't because The radiator was in the way. So I custom built the front bumper to relocate the radiator and custom built a wench me to put the witch where I wanted it. And I didn't want the fan to blowing in my face so I put it low and cut a hole in my hood that way it blows down at my face. When I did that I had to relocate the battery and all the fuses. I put A brand-new Optima battery under my seat and ran bigger power and ground cables. I cut the hole out in the center of my Dash where everyone is mounting there switch panel. And I built a custom plastic door with a lock that swings down so I can get to my fuses and relays. Well doing this I also lifted the bike 3 inches and custom chopped my cage down 6". Built the roof to perfectly fit the cage. And I was in the process of wiring the stereo up and trying to hide wires when I noticed my bike running bad 92c71e66cff3294464412ccb95eddef3
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
View attachment 45572 it's a lot of work. Started when I wanted to mount the winch high. I couldn't because The radiator was in the way. So I custom built the front bumper to relocate the radiator and custom built a wench me to put the witch where I wanted it. And I didn't want the fan to blowing in my face so I put it low and cut a hole in my hood that way it blows down at my face. When I did that I had to relocate the battery and all the fuses. I put A brand-new Optima battery under my seat and ran bigger power and ground cables. I cut the hole out in the center of my Dash where everyone is mounting there switch panel. And I built a custom plastic door with a lock that swings down so I can get to my fuses and relays. Well doing this I also lifted the bike 3 inches and custom chopped my cage down 6". Built the roof to perfectly fit the cage. And I was in the process of wiring the stereo up and trying to hide wires when I noticed my bike running bad View attachment 45573
Oh ok I've seen these pics before. Not my cup of tea but some nice fab work you got there. Very nice. Much better than behind the seat lol
misterkit
42
36
ny
Shifter holes/radiator heat. Every post so far is related that I've seen. Where did it get off track?
So the thread was discussing a custom plate the OP came up with....then it switched to relocating a radiator and folks asking for info on that. No big deal.
I will encourage people to find other ways to solve a problem other than have a thread just talking about only one way. I'm sure when the OP get all this organized and set up, he will make a dedicated thread for this product only for those who are interested.
CP: I've been saying that since that jack wagon was picking Legos from his turds:)
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Yeah that happens alot. If an op is offended it gets stopped though. One great thing about this forum is the amount of ideas that gets generated. I guess it is so commonplace I didn't even realize it. Personally I think it's one of this forums greatest assets.
Amre2me2
Amre2me2
381
1,423
Colorado
My SxS is up at our property. I'll try and remember to take some pics next time I'm up there. It was pretty simple though. I cut out a piece of foam about the same shape as shown in Montanas first post. Cut a slot with a sharp knife so the shift lever slides through it. Glue it on the backside of the panel. It stops all the heat. Cost is about .26 cents worth of glue.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Nice work! First time I have seen this picture and this idea using stock radiator! Got into some mud that plugged the radiator and caused me to overheat! Cleaning was next to impossible! I have even went through the trouble in the past to remove the front grill for thorough cleaning! But your mod solves a few problems! ;)
sugarray
sugarray
Is this a game show?
661
1,258
WV
Rigid foam or soft foam?
Reactions: sharp
walexa07
walexa07
396
380
Louisiana
I am interested in one when they are available. Great idea. Thanks,
Waylan
Reactions: sharp
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I wanna see!
Reactions: sharp
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Where are y'all finding this radiator clogging mud is what I want to know. Seriously. I'd put bull run mud up against anything short of that muskeg they got in AK. And I've never had a mud clog problem. I don't know if I should feel lucky or feel left out lmao.
Reactions: sharp and joeymt33
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
An old photo but shows I am trying lol
FB IMG 1496676460432 240x135
