P700 Cracked the windshield trailering
BadDog
31
15
I have the 700-4 with two piece hard coat plastic windshield, and factory hardtop. Never had an issue trailering with the windshield on until now. I was bringing the Honda home from our cottage at highway speeds (70-80 mph). It's about a 5 hour drive. I stopped for gas about an hour from home and noticed the upper edge had caved in from the wind. There was a 3" crack near the top. I popped it back out and slowed down (to 60-65 mph) for the rest of the drive. When I got home the windshield had caved again, despite traveling at reduced speeds.
I'm thinking about cutting a piece of plywood to cover the windshield while trailering. Not sure yet how to protect the windshield from scratches from the plywood. I'm interested to see and hear what others have done.
Removing the windshield to trailer is not a good option because I don't normally have extra storage space when hauling the Pioneer. In the winter I add soft sided doors for ice fishing, and to keep snow out. If I end up removing the windshield to trailer, I'll end up needing additional storage space for the doors. Now I just use bungees to hold the doors closed when trailering in the winter.
Drilling a small hole at the bottom of that three inch crack should stop it from spreading. Putting some sort of fabric between your plywood and the windshield would probably protect from scratches, but if it rained and got the fabric wet and then froze, I’m not so sure. And the plywood would need to be secured so tight that there was zero movement in it from vibration and bouncing going down the road, IMO.
Reactions: Eltobgi and jinx
319,956
Use plastic capillary glue on the crack and it’ll more then likely fix it. If it’s clean when you apply it the crack can be nearly invisible.
Backwoods
Backwoods
32,342
331,954
Douglasville ga
I take my top piece off when I haul mine put behind seats in truck. You could wrap it in an old blanket and put in your floorboard and dash In your 700. It would be easier than plywood Honda clips make it a 3 minute job.
O
oldfortyfive
595
1,316
Illinois
As suggested you will definitely want to drill a hole to stop the crack. I use a piece of 1x2 across and behind my half windshield to support it when trailering. That may be all you need to do. You may also want to got some temporary removable protective plastic film and lay a strip across the windshield for trailering too. I ruined my full windshield by having a tarp over the front of the unit and it rubbed a gazillion scratches into it. The film would have prevented that.
This is what I use: Windows Protection Film
MikeG
MikeG
359
2,478
Baton Rouge LA.
If you go the plywood route just glue felt to the side facing the windshield
Reactions: TimG
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Reinforce the backside of the windshield where it bows when trailering using the ROPS as support for something like a bar and pool noodle. It may help to sit in the 700 while being trailered down the road and see what is failing and causing it to bow. The solution might just be to mod your windshield by adding additional clamps. Good luck
Reactions: TimG
7,143
27,169
I used to put a ratchet strap around the rops and both the straps behind the plastic windshield. Just make sure the ratchet parts dont touch the plastic.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
I used to put a ratchet strap around the rops and bother straps behind the plastic windshield. Just make sure the ratchet parts dont touch the plastic.
That’s a great idea
7,143
27,169
@jrplaza2008 has been using this method since the 2015 Takeover.
Reactions: Montecresto
Benjy
Mississippi
Had mine do this same thing when on a trip. Found that if I opened the window up a little, just a couple of inches, I didn't have this issue anymore. I am guessing that this changes the impact point of the air on the windshield and actually deflects the air up rather than driving it into the top of the windshield.
Dallasaero
Dallasaero
16
12
Poplar MT
Colby Canvas will build you the best windshield cover ever. Their number is (785)462-3981. They are great people to work with and the service is unbelievable. I've used them for my tractors, boats, and SxS. Great workmanship.
WillyBill
WillyBill
Wheeling Addict
473
1,887
Clinton, Utah
  1. Talon X LV
I put one edge of my windshield into a piece of aluminum channel (1/2 tall x 3/8 groove just barely shorter than roll cage inside span) glue in with epdm rubber caulk. Made it waaay stiffer. Wife said I need some of that for me too.
Hwysupr
23
35
Had my 2 piece for 4 years making many trips down south for hunting and always fold down the top. Run 70 to 75 on interstate and never an issue with the windshield.
