Cummins Built Not Bought/The Life of Frankie.
Outacntrl
Outacntrl
111
326
Kansas
No I hadn’t. I looked for that too and a couple people suggested it but no evidence. It’s said that trans splashes way more on right side, where filter intake is located, then on left and that’s way it’s suggested on that side. It’s just taking small percentage through gravity. I can’t see a problem.
Everyone says run the 4500 1 qt high to help eliminate starving.
Yeah my only concern would be in the dead of winter that thick fluid not getting back through the filter fast enough until it got some heat in it. Probably be fine though.
Reactions: J80 and Mudwing
322,675
Again it’s a passive system, here are pics. It doesn’t need to have fluid passing through. If it didn’t pass through it would act exactly like it did with the pto cover back like stock. All the fluid doesn’t run through there, just what the opening “catches” then it flows through the filter back in. If that cavity were to fill up it wouldn’t catch any more and simply fall back into the trans like normal. It’s a simple system, people are overthinking it. Thinking it’s a conventional filter that can clog up and restrict flow, that is NOT possible.
Truthfully I doubt it flows till gets warmed up but that doesn’t matter, it can’t effect lubrication to the trans in any way
6E2DB2EB 3561 4573 BC0F 43412A13FC6B26687571 D6BF 48C4 B23D 85C45C4198B0B0ECA75F D25E 4D07 BF89 1D8C84832FBB14270C02 D17F 4239 8306 D09CA37D677B
906UP
906UP
14,406
136,902
da Yoop
View attachment 236394View attachment 236395View attachment 236396View attachment 236397
Ahhh..... I get it now
322,675
Been busy as s*** on the pickup the last few days. Decided on the Bilstein 5100’s spent so much time online making sure that’s what I want and they will work on the truck. There’s just nothing else to look into. I’d bought a different set but thankfully they didn’t have one so I canceled order. Took awhile to find a full set of Bilseins, last two finally showed up.
Shocks I pulled off were s***
4AFF214C E137 4A12 B0B8 283DA15E24DC
Also got my new front springs in, fronts were compressed 1.5”. All new I-bolts, bushings, bolts and shackles. New springs are lifted 1.5” over stock to level the truck. It’s now 3” over the worn out mess it was.
AE96F6F4 6E55 4EA8 B926 89EAC46CF210
Pulled the trigger on a set of Warn Premium locker hubs. They are so much better then the stock Warns. No plastic and full turn for more positive lock. To be fair though the stockers were working.
E97D7995 E7ED 426D A6E3 C14617A0509B
2BB2FE84 173B 422A BA17 35BB0C244C70
208,730
View attachment 238479View attachment 238478
We are all pulling for you, just expensive on the tail end! Best wishes from us all!
322,675
It’s now ready for the front end body parts to be assembled before anything else up there so it needs to start with the doors and work forward for fender alignment. Back doors went without a hitch but after spending a ton of time trying to adjust the new aftermarket front doors I said f*** that and went backwards a bit using the best of the doors I had laying around. There’s no rust but both are beat to s***.
Was trying to get out of bodywork but I guess I know a guy lol.
Getting old Dodge gaps decent isn’t fun but I’ll get them ok.
D4974A9C 68FD 4D1D BE69 9DF142153D32
13762A33 1C81 4378 B432 94B293AD8D82
Got a bit yet getting them lined up, then start getting core support,fenders and inners in. Then comes the rest of everything under the hood that isn’t finished.
3E1F1589 A3E2 4CF2 86FC 7D821F033377
Ran the rest of the brake lines and got them in buttoned up finally. So controls are all there, steering, throttle, brakes and clutch all done.
Also spent a little time bouncing a few things off of @snuffnwhisky, he’s a great suspension guy so I appreciate his thoughts.
322,675
Found a cracked throttle linkage today, something that may only take a min and a zip tie on the road to get home but not chancing stupid crap. If the original plastic lasted 30 years then this should be good lol.
971BBB3B 7553 4AFC BDD1 D70CC91837C77F264CC5 5364 4F0A 85EA 1762697D3C77
322,675
Starting to get things laid out. Needed to get core support in to check the intercooler lines.
Now that’s a radiator!
AAFA4267 741A 4A86 B0C7 584986445613
BD4E1B0F F745 49D9 8A9A E9CD2767FF55
