P1000 Cup holder Mod
T
texaswakerep
24
24
Hattiesburg
Like many of you, I felt that the cup holders in the Pioneer were a failure. Hasn't Honda heard of the wildly popular Yeti beverage holders? After reading through the forum on this topic, I decided to try something a little different. I had 2 extra stainless steel cup holders from a project on my boat. One of the cup holders is a single inside diameter, and the other has two inner sizes like this: Amazon.com : Amarine-made Stainless Steel Cup Drink Holder with Drain Marine Boat Rv Camper : Boating Deck Hardware : Sports & Outdoors
After testing both sizes of Rambler tumblers, a 12 oz can, a bottle, a can and bottle with a coozie, and a can in a colster, I decided that the cup holder with two inner sizes would be best. All of the above beverage holders fit inside the holder. And all were snug with the exception of the colster....which fits inside, but moves around in the holder. I figure I can just wedge a coozie in beside the colster to keep it still.
Installation was pretty easy. Remove the oem cup holder as described here: P1000 - In dash cup holders Next cut the oem cup holder holes out in the dash (I used a dremel...and I carefully picked location, hole size, etc several times before cutting because I didn't want the hole to be too large and I wanted to make sure the top outer rim fit flush.) Remove the sticker off the adhesive ring, drop the cup holder in the hole, and press down so the adhesive does it's job.
IMG 8129
$12 later, I'm now happy with my new cup holders. I may have to go back and add some additional adhesive on the underside of the rim at some point, but it seems to be fine so far. I wish my colster fit better, but this cup holder gives me more options over OEM.
***DISCLAIMER: I don't recommend you cutting your dash. I assume no responsibility for what YOU do to YOUR vehicle. :) ***
sthomp54
sthomp54
375
Great idea, the 500 has the same cupholders that are only good for small diameter cups/cans, may have to try this!
dale5740
dale5740
886
417
mt airy md
will this cup holder hold a 32 oz Gatorade bottle
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Great idea! Thanks for sharing. May have to try this
ibleedjohndeeregreen
62
62
Iowa
Does a Yeti can Koozie fit in there?
sthomp54
sthomp54
375
Got the plastic ones in. I didn't want to cut the dash so I put it on top and screwed it in. Pretty sturdy. Can finally fit a yeti!
IMG 20160709 151648
IMG 20160709 151655
Cohutta
32
29
NWGA
Thank you, OP.
The plastic ones don't seem to be the same dimensions in the description.
Jeffro
106
47
Louisiana
I got some of these today and nothing seems to fit in them very well. I have to jam the Yeti in where it's so tight it seems like it will pull the cup holder out with it, and everything else is very loose. 32 Gatorade does not fit in the ones I got. What am I missing here? Are they better when installed.
Mine aren't installed.. coke cans fit fairly well in the lower portion but would be better if they were deeper.
These are the ones I bought
https://www.amazon.com/gp/aw/d/B013D7TXZO/?tag=sxsweb24-20
