Are you the guy i have been talking to on FB about this? Man i am super interested if you make a kit. Also just a thought it would be awesome if you could make it so their are barbs that all the diff...ect can connect to
Do you think the three inch is needed? Isn't the current one only 2"? Also remember the amount of piping being used after the new box is less than half of stock setup. Just throwing ideas out. I would be very interested if you could make a setup for me to purchase. As long as the bed is dumpable.
OK I see what your saying!! If the top part is made it should be all that extreme. The bottom hose could just be capped off I suppose?
My snorkel kit runs 2" directly from the airbox and I have noticed zero power loss. I figure the factory snorkel is as big around as it is because its so dang long.
Yeah my snorkel is 2" as well, and I didn't notice any power loss, but you have about 8 feet of hosing from the air box, so I feel like I might get a little something out of it snorkeling directly from the lid, plus my snorkel runs on the outside of my roll cage, and my luck I'll end up running it against a tree and destroying it. Lol
Yeah that's nice as well, and I really like the camo plastics, I'm going to have to look into buying those! LolThats one of the reasons I went with the Triangle ATV kit versus the High Lifter kit, I didn't want to make the intake any longer, so I probably gained a little buy reducing the overall length and bypassing the original intake even with using 2" tubing. Mine runs directly from the rubber coupling on the air box to the gas tank area, and then up in between the passenger seat and door.
Can you comment on how the Triangle Atv kit works for the passenger. If a full size adult sits there, do they notice it at all pertaining to space or noise?Thats one of the reasons I went with the Triangle ATV kit versus the High Lifter kit, I didn't want to make the intake any longer, so I probably gained a little buy reducing the overall length and bypassing the original intake even with using 2" tubing. Mine runs directly from the rubber coupling on the air box to the gas tank area, and then up in between the passenger seat and door.
Sent from my KYOCERA-E6560 using Tapatalk
