Custom Switch Panels for P700 & P1000
Status
Not open for further replies.
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Yes sir, no problem. Let me draw something up and I'll have you make sure it looks right. Which pioneer do you have?
1000-5D, looking at flush mount for ssv. Thanks please include aux input as well
Harman24630
Harman24630
283
493
Tazewell Va
Is there enough room on a 700 for this configuration?
Reactions: mystic1219
mystic1219
mystic1219
191
202
B1ee6b2218190ee3665df49625fd87ea
Kinda like that? It has 2 extra switch cutouts but they are easily plugged.
Reactions: knuckledeep
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Image Mystic1219, I was thinking something like this. Of course this isn't to scale.
mystic1219
mystic1219
191
202
View attachment 13162 Mystic1219, I was thinking something like this. Of course this isn't to scale.
Uploadfromtaptalk1459997409631
Thats about what I had in mind. do you know the outside dimensions of the face on the ssv controller (how much real estate it's going to require on the panel)? I *think* I can get all 8 switches in there if you are going to need them. That's just a quick sketch but would be tweaked. The panel and switch dimensions are to scale.
mystic1219
mystic1219
191
202
Yes that will work I just didn't know if there was enough room with eight switch cutouts for the small circles. Are the small circles knock outs or just dimpled
They are knockouts. It's tight but I believe everything has enough clearance. The Jensen radio only overhangs the 3" hole by 1/2" (1/4 over the edge, all the way around). The volt meters barely overhang their cutouts.
Harman24630
Harman24630
283
493
Tazewell Va
I like this one pretty good cause I'd rather have an extra round hole than two extra switch holes
Harman24630
Harman24630
283
493
Tazewell Va
I'm most likely gonna order this one from u... Is it possible to have the switches as knockouts too I know it would risk bending because of the lack of material between but I'm not above using a dremel to get them out. I know I can get the plugs for them but for the time being I'm only gonna have one switch for the stereo and prob never need 8 but I still like the option.
Eltobgi
Eltobgi
4,599
15,187
North Dakota
The flush mount controller hole is 1.75" and aux is 1". Not sure on outside dimensions of the face. To be safe, 6 switches are plenty, to provide a little space between controller and aux opening.
mystic1219
mystic1219
191
202
I have a few left in stock for all 3 models right now and I'm placing another order on Monday. Let me know if you want one.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Madore128
175
291
Ma
Which ones do you have in stock? Ill prob grab one that u have now.
mystic1219
mystic1219
191
202
Here are the p1000 panels I have right now. The top left has a round knockout for a volt meter, 12v or usb outlet. The top right has 2 of them
Uploadfromtaptalk1461501356143
Reactions: Tot
Jediwrathchild
Jediwrathchild
212
410
Kodiak, AK
How much for the one right in the middle? The one with a stereo cutout, 6 switches and the voltmeter spot?
Greg
283,826
Greg
The first post has the pricing, they are $25 for one or #20 each for two or more. Seller is @mystic1219 Not sure about shipping to AK, he will have to answer that.
MAV
MAV
41
14
OHIO
Can you make me one like this Mystic1219? Placement doesn't matter as long as it doesn't interfere with the gears.
Honda1000 5Dash
mystic1219
mystic1219
191
202
Can you make me one like this Mystic1219? Placement doesn't matter as long as it doesn't interfere with the gears.View attachment 14410
I'll have to see if I can make it all fit. Not much room left for a panel haha
Harman24630
Harman24630
283
493
Tazewell Va
Has anyone used Honda rivets to mount these? I've ordered one just thinking of using them to have a slightly more stock look.
Reactions: Tot
Status
