P1000 Dash gun mount and switch panel
P
Pbarou1
10
Louisiana
I haven’t seen this on any forums. It may have been done before but wanted to show my dash build. I put two Rhino XL mounts on the dash for vertical gun storage. Around it I was able to squeeze in an accessory usb outlet with voltage meter for the second battery and a smaller switch panel. Normal rocker switches would have been tight. It’s worked out well. A few accessory light bars on the front and back.
02E64EEB 20DD 426D 9497 E11F5EA52791 E42CFB7B AA38 474E 87A6 E2361D558D36 261B57AF 8207 40CA BEB9 EF9CA83B40EC EE7B6E42 42E4 48CC A2D0 0DDE7CB659CD
Bighat
Bighat
909
3,866
Gallipolis Ohio
I like that. I have a gun grabber mount I took off my gator and I've be trying to figure out how to mount it. Do you have a metal plate or a metal plate behind your dash panel that your mounts are attached too? The type of mount I have, I need something solid to attach to because you force the gun in and out of the mount. I have a plastic plate and it would never hold that force.
Reactions: Biteme
P
Pbarou1
10
Louisiana
I did not put a metal plate or backer. You can accesss the back if you need to but for this mount I just bolted through the plastic. It’s a pretty wide base so it seems sturdy enough, but there is a little flex in the plastic. I haven’t taken it through a full hunting season yet but I think it should hold up. You could consider a thin sheet of plywood or using something like a plastic cutting board cut to size to reinforce it.
