P700 Dead Battery
Clarky
108
Tried to start my Pioneer this weekend, but it wouldn't turn over. I have been noticing my voltages haven't been as strong. It's 2 years old. It this the normal lifespan of an ATV battery, or should it last longer? I did just install a soundbar, but it is supposed to not draw any power when off.
swsebek
swsebek
2,854
5,835
pa
Should last longer than 2 years,but in cold weather you should have a 2 amp trickle charger on it....My oppinion is honda should put car batterys in these things.Especially all the crap we like to put on them
Reactions: allgm1 and Tflynn
Clarky
108
Was definitely cold here this weekend. Unfortunately, where I store it, there is no electric.
G
GhostComanche
9
11
Mine went dead on the new P2 700 within a month of purchase.......................unit would only click when turned the key. Unit sits in a climate controlled shop. Called dealer and they said to bring it in for checking out. I hooked up a 1 amp trickle charger to it and let it sit overnight................no problems since the charging. My conclusion; The battery went very weak while sitting from the time it was built to the time it was delivered to me by the dealer. If it happens again, I will be upgrading the battery on my dime...............JMHO.........................RR
Clarky
108
Quick question. I think I know the answer, but just want to make sure. My charger has 2 settings. I don't remember exactly how it's worded, but something like 1) Maintenance Free, 2) Deep Cycle. What kind of battery is in the Pioneer? I am assuming it's like a regular maintenance free car battery, just smaller. Just wanted to make sure.
I jumped it to get it into my garage. After shutting it off, I checked the battery voltage, and it is showing like 0.1 volts.
swsebek
swsebek
2,854
5,835
pa
Sounds like you need a new battery,charge it for
Its not a deep cycle,its maitenence free.10 amp is a good charge rate.....put it on charger over night,check it tomorrow.it should keep 12volts.if it don't then get a replacement.If it were cold and that battery was dead they will freeze and bite the dust...If you don't use them often you should keep a trickle charger on it,or at least start machine and let run once a week.hope this helps.Sorry no one else chimed in.most of the time they are very informative on here....
