Multi Defective regulator, refund hassle
Mudder
Mudder
NTC Ambassador of Walls
11,657
88,025
Got a replacement Regulator from Madhornets.com which I am trying to get a refund on as it is defective. No charging and battery drains while engine running and lights on. An email with description of the issue was sent and NOW they require a video for proof. Not a Youtuber, but figured out how to post a crappy video. Got a Honda OEM replacement and P500 works fine now. Time to escalate to Paypal.
FBD7DA97 7D6C 4FB3 A7A3 9C2B6FB5488D 8AF9E671 8E24 4136 A540 E860D7FAFDA0 24783E2B A694 470F A976 EEBBA53CF7A2
Bradley-Thornton
Bradley-Thornton
684
1,649
Hattiesburg MS
Have you tested your battery? If your battery is bad this test want work correctly when the battery is connected or at least I wouldn't think.
Can't watch the video on my work computer so I can see the test.
If you have tested the battery and have a good ground then I don't see anything else it could be.
Mudder
Mudder
11,657
88,025
Replaced battery at start, that’s when I started checking voltage and engine per service manual. Thanks for input. Here’s the original thread for viewing pleasure at home. Just posting for others info. Very first problem after 1900 miles. Multi - Help. Voltage high and climbing
Reactions: Mudwing
