P1000 DEI Heat shield problem 2023 PK1-5 Forest
DawgU
DawgU
60
161
Oakland TN
First, apparently if one is good, two's not necessarily better :). Decided I would try to install both the DEI and the Quick Shield. The DEI is not made for a '23. Have multiple push pins where there are no holes in the shield. Also sometimes HELL trying to get push pin in even when there is a hole. Those problems exist without any presence of the Quick Shield.
Suggestions? I'm just trying going without the push pins where there's not a hole.
DawgU
DawgU
60
161
Oakland TN
You could install rivnuts where the push pins are. Then you can have as thick of coverage as you desire. Just hold it all together with bolts.
Well I had ordered a rivnut tool yesterday for my skid plate install, so that sounds awesome! Never used one before. Will it work with flat plastic to flat plastic? Thank you!!!
Robobrainiac
Robobrainiac
2,460
8,569
This is the style I would use when installing into plastic.
I have used this style on many areas of my pioneer where I want anchors into my plastic.
I am not sure if it would work on floppy rubber. Although my brain says if you used a washer on the backside you could probably attach them to rubber like a ring attaches to a tarp.
Robobrainiac
Robobrainiac
2,460
8,569
I used rivnuts under my seat for my under seat fan bracket. The names can sometimes be confusing.
I used rivnuts for my skid plate.
I used shank nuts for all my plastic areas.
These are typically rivnuts
I use these in metal. They slightly swell and make a solid contact.
41Uo0dnz hL AC Rivet nut tool rivnut 1457364438 28d29906
These are typically called jack nuts.
I use these in plastic. You can see how the back swells larger which typically makes better spread contact on plastic.
41kd7FbOLnL H 265 2 LR
These are typically called pre bulbed shank nuts. I personally prefer these over the jack nuts because the walls are typically thicker and it feels like a more solid nut placed into plastic. They are sometimes harder to find and more expensive. They spread the same way the jack nuts do.
71 nnk6UmbS AC UF10001000 QL80
I use both of these style of tools depending on the location and ability I can reach the area with.
Images 58078 W3
Robobrainiac
Robobrainiac
2,460
8,569
Post #154 is my layers of heat defense experience.
ChadD
ChadD
23,136
231,947
Brown City
View attachment 396826 View attachment 396827
View attachment 396828 View attachment 396829
View attachment 396831 View attachment 396832
You sound like a Yamaha owner with all that knowledge about nuts 🙄🤣🦩
#NTC
#NOMO
Bighat
Bighat
875
3,737
Gallipolis Ohio
With the new cover honda has under the seat I would think you could use a thicker heat shield. I haven't made one myself but I did look into it. Here's some links: Thermo Tec 14100: Cool-It Mat 24" x 48" - JEGS
You could install them with rivots, spray glue, velco, etc. You want the shinny side down toward the engine compartment.
Backwoods
Backwoods
32,380
332,365
Douglasville ga
You sound like a Yamaha owner with all that knowledge about the females🙄🤣🦩
But I’m a vegetarian myself. I don’t eat meat but I sure like the bone
#NTC
#very Homo I am
It figures
  • Haha
Robobrainiac
Robobrainiac
2,460
8,569
Got both shields installed today. The rivnuts were awesome! Thank you Robobrainiac!!! Took it for a good test drive today afterwards. Difference is amazing!
I am glad it worked out. My wife and I feel the shields and fan do a very good job at reducing heat. I think a full rubber sheet should have been factory provided for sure.
