Plumber101010
what research lead u to come up with the decision to run that weight rather than what was recommended? Im sure u have a good reason could u share what got u to that conclusion.
can I change it now I have 200 miles on my pioneer ?
Lol...Can someone tell me how you get the oil in the front diff with the way these diff oil bottles are shaped. I mean I go to put the spout in the fill hole, and it looks like you can't tilt the bottle enough to make it work. Do I need a small hand pump?
Amsoil 75w-140 sever gear.amsoil Severe Gear® 75W-140 or Royal Purple 75w-140 ????? what do you guys run?
I have a link to a funnel sold at Walmart that has an 18" flexible tube that easily reaches the difference, sub transmission, and engine fill holes. See post 1I'm pretty sure my old atf funnel will work. I haven't drained the diff's yet, just making sure I'm ready when the time comes. The rear looks pretty easy with the bed up.
Was reading up on the diff change procedure and noticed that you never received a response to your question.I would like to try 75w140 to quiet it down, but I'm a little hesitant living in Maine, and I plan on using the machine ice fishing. So I'm not sure if the heavier weight oil would cause problems in the winter. Any thoughts on that ?
@Hondasxs was doing my full initial service on my 2018 LE. Noticed differentials front and rear were noticeably larger than my 2016 1000-5 Deluxe. Sure enough owners manual for my LE called for greater oil capacities at draining. Updated giude above today noting LE model capacities in bold red.Again, Thanks to @JACKAL for providing another wonderful how-to guide.
