P500 dobeck AFR+
solrus
solrus
1,629
2,511
Montana
Any underwater stones during installation?
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Never heard that one either lol. I'm guessing unseen problems??
makes sense lol ut no problems at all i just had to extend the power cable because of where i wanted to mount it but other then that it was very very simple
solrus
solrus
1,629
2,511
Montana
Correct. Unseen problems.
If I leave it connected to the battery and not extend cables, will it drain battery faster?
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
you would think so right????? i didnt want to chance that and it was nothing to run a power cable under the hood when i was running the gauge line
solrus
solrus
1,629
2,511
Montana
this is where i mounted the o2View attachment 37966
So I finally strip everything down, in the instruction is says that O2 sensor should be mounted in 5 degree angle, on your pic it looks more 45 degree ? Not sure why they say 5 ?? does it really matter? Please elaborate on your thought process.
They say that angle is the best scenario for condensation to not settle in it or hang from it.
solrus
solrus
1,629
2,511
Montana
So , it will work ok mounted under any angle?
solrus
solrus
1,629
2,511
Montana
I have finished install today too, still have stock exhaust, which should be changed too.
Jak , I did not extend controller wires and connected them to the battery directly, looks like , the LED gauge is not powered when the ignition off, only when its on, it blinks.
Now I did not get how can I turn into yellow or red mode and keep it on, i press mode button it turns into red but goes back to green?
solrus
solrus
1,629
2,511
Montana
Jak, one more observation when I start engine it turns greens, then i accelerate it goes into yellow blue or green blue, dont recall, I do not observe to be in yellow or red mode.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
ill have to look next time i go for a ride and ill get back to you
solrus
solrus
1,629
2,511
Montana
Did you use preloaded settings or changed them? if changed to what values?
pic with each setting ( exp green , red , yellow) would be great
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
i adjusted them a bit but im running different exhaust
solrus
solrus
1,629
2,511
Montana
I need to sit and learned what to do with it now . But still not sure how to stay in yellow or red mode, mine just jumps from green to green blue I think. Feels better on acceleration , will modify exhaust soon also
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
it auto moves while ur riding it wont just hold in 2 zone
solrus
solrus
1,629
2,511
Montana
Jak when you welded your exhaust , why did you took off catalytic converter? does it really restrict the flow?
I thought about just redesigning OEM exhaust can and add super trap exhaust , but leave catalytic converter ?
Any thought on catalytic converter? Leave or cut it out?
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
the cat is huge and definitely restrictions the air flow if i need a spark arrestor in order to ride somewhere the hmf has 1 that can be swapped in about 1 minute
