P1000 Door bolts
Tuco69
Tuco69
1,474
7,563
Middle Georgia
Ok, is it just me or did Honda use very cheap hardware. Was planning to swap out oem with RB3 parts. Got two bolts broken loose an third stripped head. Ideas on getting out with buying specialty socket?
Mudwing
Mudwing
36,959
306,564
The Mud holes
Not sure where the broken bolt is, how accessible it is? But you may have to grind, drill, and easy out it. Maybe some heat to soften up loctite.
Reactions: Hondoman
Hondoman
Hondoman
727
1,697
Texas
I stripped the head of one of mine too. Honda torques them too much. I drilled the stripped head off, then the "stud" came out easily. I think i found a replacment bolt at home depot.
20180204 141110
Mopower58
Mopower58
CST is the Best!
71,721
655,608
Crystal Springs,Ms.
I used a 6 point socket with a ratchet to break mine lose then used a rechargeable impact to take them out and reinstall them.
Reactions: Tuco69
Tuco69
Tuco69
1,474
7,563
Middle Georgia
Will be something to do this weekend, rain in the forecast. That an other undone mods. PITA, same bolt on opposite door did the same thing.
Hondoman
Hondoman
727
1,697
Texas
Sometimes you can drive a 12 pt socket one size small onto a stripped bolt head with a hammer. It didnt work in my case but it might for you.
Reactions: Tuco69 and Mudwing
RB3offroad
RB3offroad
1,704
4,770
Tempe, AZ
Wow, I am sorry to hear this. I know some people have been saying how the bolts are way overtightened or even that they got wet and had a hard time backing out. Did you completely round the corners?
RB3offroad
RB3offroad
1,704
4,770
Tempe, AZ
You could also take a small file and try to refile some flats on the bolt and try to get a little smaller socket onto it. pb blast it maybe.
S l400 not sure if something like this would work either? I have never tried one personally
Kilo427
Kilo427
1,543
6,439
It not uncommon has happened to me at least 4 times on the doors, drill it or hammer a small socket on it. Certainly would help to use a penetrating oil of some sort as well.
Reactions: Tuco69
Tuco69
Tuco69
1,474
7,563
Middle Georgia
View attachment 64265 not sure if something like this would work either? I have never tried one personally
Going to pick up an “easy out” from Irwin this week. Thx.
Mudwing
Mudwing
36,959
306,564
The Mud holes
One other way would be to cut into it to fit a big flat tip screw driver and impact it out. Just trying to help. Bolt extraction can become like surgery!
Reactions: Tuco69
