P1000 Door Seals??
ElmerFudd
ElmerFudd
64
119
Tried to search didn't find anything. Anyone have a good fix for the gaps in the front doors big enough to throw a cat through?? Dust in summer and snow in winter is terrible!!
Reactions: Vikes79 and Isaiah
Vikes79
Vikes79
SKOL!
11,684
113,340
South Dakota
  2. Talon X4 LV
Check out the door seals I’m using. They are still going strong.
Lady01
Lady01
192
488
Midland Michigan
I used 1/2 by 1/2 square foam tape on my doors, had to cut it almost in half in some locations but still needed the 1/2" thick at the bottom of the doors.
1592334549854
Since I had to cut it by hand it is a less than desirable but when the doors are closed cannot tell. I used spray adhesive on the door edge where I thought the stripping would go... that and the adhesive backed strip foam it is really holding up well in the heat.
However, I really liked what Vikes79 did with his machine, and you should seriously consider it!
I love my seal strips, keeps the cold and dust out, and it does indeed reduce the door rattling.
Reactions: Isaiah and Vikes79
60,256
If you smash the side rails into enough rocks, they will eventually close that lower gap right up when they push up on the floor plastic. Free mod!
Paul_H_L11
Paul_H_L11
20
40
Covington, WA
I found a great guy that makes some sewn seals. Great quality kits. His name is Brandon Beesley in Utah. His email is [email protected]
His phone is (801) 750-3459. I bought a set.
  • Honda Pioneer 1000-5 Rear Door Seal Instructions.pdf
Reactions: Lady01 and ChadD
W
Wyo307
25
101
Wyoming
  1. Looking to buy
  2. 1000-3
I wish I would have read your thread before I ordered what I did! I just got regular bulb seal with 3M backing. I think it will work but it looks like yours has a larger adhesive area and may be more durable. If mine fails I will definitely go with your idea. Thanks!
Reactions: Lady01
