Driving with snow plow
Rudy5050
7
10
I have a 2021 Honda pioneer 1000-5. I drove it 5 miles with the snow plow on. I was running about 45mph and the temp guage hit 3 bars which I have never seen it past 2 before. I am assuming the plow was blocking the air flow. No dash lights or warning light came on. Should I be ok or should I be worried that it overheated?
Reactions: TxDoc and Smitty335
lee
lee
Village Idiot
2,386
13,515
Springfield Ohio
That's not hot yet.
There is a warning light on the dash to get your attention if it is truly getting too hot.
Just watch the temp when roading the plow.
Vikes79
Vikes79
SKOL!
11,708
113,600
South Dakota
  2. Talon X4 LV
I wouldn’t worry about it.
check the radiator level and motor on IMO.
Spidy
Lancaster Ohio
I just would be careful plowing in high
I have a 2021 Honda 1000-5 also and I plowed for at least 3 hours and never went above two notches on heat gage but I only plowed in low
But as long as you hear your fan come on it’s probably fine
Rudy5050
7
10
I havnt been able to push snow yet..I should be Plowing next week. We just got ice this time so I was only spreading salt. Which anything below 20ish I keep in low. I spread salt in low for 6 hours in town today with the plow on and no issues. It only happened when I got on the main road in high and drove faster.
rickoshea
i run around with my tracks on 6 months out of the year and see 3 bars regularly when i'm running hard at max rpm's.no issues so far.
208,726
That's not hot yet.
Does the plow bock air flow to the radiator?😒 HA! Think the extra weight might have something to do with it?
Reactions: trigger
Rudy5050
7
10
1 last thing. Will this handle pushing the snow if we get 12+/- inches of snow? I plan on throwing my factory tires back on that are more aggressive then my road tires.
IMG 0654
Reactions: TxDoc
Rudy5050
7
10
I may or may not have had 700 pounds of salt in the bed as well...🤫 and the plow.... plus my fat a$$...
208,726
Think you're on to something! HA!
rickoshea
what size blade? i have a 72" and have to watch my speed when i'm pushing into a big pile.i do a hard stop if i don't raise the blade as i'm pushing into the pile,but i plow with my tracks on so traction is a non issue. so, slow and steady.also i have to be careful and not hit anything at an angle when i have it set straight.12 inches in a straight push is no sweat.
Reactions: TxDoc
Rudy5050
7
10
I have a 72 inch as well.
Reactions: TxDoc
Spidy
Lancaster Ohio
Then I would say you were correct the plow it’s self might have been blocking air flow
But it’s a Honda they will run forever
Reactions: TxDoc
Vikes79
Vikes79
SKOL!
11,708
113,600
South Dakota
  2. Talon X4 LV
You’ll run out of traction long before power.
if I know that I’m in for a big dump of snow, I’ll run the plow about 1/2 way thru the storm just so I don’t have to manage that much at once.
Reactions: TxDoc
