P1000 Dual Battery Needed?
N
nzeb
9
16
Green Bay, WI
I currently have a 2018 pioneer 1000-5 deluxe. I'm adding a front light bar, a rear light bar, and rocker lights all on individual switch's. My question is should I do a dual battery system? I will eventually do a BT stereo and possibly a heater down the road and would prefer to do it right from the start. Also if anyone has any HOW TO links on setting and hooking the lighting systems up it would be greatly appreciated. I'm pretty hand especially with plug n play type systems but figuring amps, draws etc is way over my head. Thanks!
113,736
@nzeb Or Here! Pics Or It Didn't Happen 😂
Welcome to the club from another Michigander!
First thing we like from FNG`s is pics! Hence the phrase above 🥳
What Scoopy posted will help for sure!
If ur running that much stuff I'd recommend a second battery
Bama-Daniel
Bama-Daniel
763
7,552
Priceville, Alabama
I believe the 2nd battery is good for the extra accessories your talking about. The extra draw on the system and any possible I’ll effects on the is clutches is what made me add mine. I knew not much on wiring before I did mine but researched on this site and wasn’t too bad.
StewB
StewB
711
3,295
What they said above, including about powering the electric clutches.
Several great threads on this site, and most use an isolator.
N
nzeb
9
16
Green Bay, WI
20191129 110037
Sorry it took so long to post, this was a little over two years ago in Northern Wisconsin during the Annual Deer Hunt. Unplowed fire roads through the state forest with 10" of fresh snow. It was a fun ride.
StewB
StewB
711
3,295
Scoop, this was a great video and gave me a lot of great info. I do have another question, when you get the wire harnesses for say a light bar they have a relay, where do you typically mount those?
The options, best spots, change depending on year and where you've installed other shtuff.
Left to right, my three relays are the main fuse box key on power relay, front light relay, and I recently zip-tied my last one (rear light relay) to the under hood cross bar because I felt lazy that day.
(If you use a fuse box, you can get rid of the inline fuses.)
1641336016317
113,736
Nice! Got to love fun in the snow!
Reactions: Lady01
Bow4life
Bow4life
128
534
Minnesota
Heres a good option for adding relays for your accessories. I'm adding one to my 1k5 for the extra lights I'm putting on. I already have the second battery setup. It's really compact and saves alot of space over adding multiple full size relays. You can order the relays right there too. For some reason I cant find the 5 relay block that I have. Once you start adding multiple accessories and the related wiring space gets pretty tight under the hood. Where do you hunt in Wisconsin? I hunted a couple years in the Ashland area, pretty country out there.
Reactions: Lady01 and Ogg
