P1000 Dump Box
P
posterboy
Well I found something that I see needs improvement. The Dump Box shock is not enough. I have owned many Rangers and I could sit in the seat and reach back and hit the lever and give it a slight assist and be able to dump a pretty heavy load like wood logs.
Well I use the pioneers for the first time today. Had some old Stray in the back. About a bail and a half of small bails. The lever is in a good spot . pulled the lever and it did nothing... The Ranger would have just dumped that light of a load. I had to give it allot of assist. So I decided to dump it with nothing in it and same result. Pretty disappointed in the shock. I will be looking into a heavier one soon.
I've thought about this before for my P700. Still may look into it. Most manufacturers of those things list the dimensions and lifting force on their website.
Now we need to see if the 700 and 1000 use the same one....ill check mine later.
Dallas
Dallas
81
58
NorCal
I believe it's because the pivot for the dump bed is farther back...much farther...than the Rangers. Mine is already hard enough to close, I doubt you'll get a shock with enough oomph to make a difference due to the pivot location.
Reactions: Everett
66,869
Seems this is by design as the 1000 will not self dump either! With a slight lift it works great.
The 1000 does have a different shock. It looks to be longer then what I remember on the 700.
Best option would be a actuator.
322,690
Best option would be a actuator.[/QUOTEfound this not sure if there is room and didn't check size difference but looks as if it would go
Reactions: Hondasxs
Stauvo
Stauvo
633
910
Minnesota
That looks good.....pull the latch, flip a switch in your panel and dumper away.
Dallas
Dallas
81
58
NorCal
While we're on the topic has anyone seen or rigged up a safety setup for say if you were transporting people in the bed? Wait...that MAY be why the pivot is so far back. So the 5 seaters aren't prone to dunping people out if the latch came undone?
On my P700 the bed dump lever is locked when the seats are up. I guess one could dump people while they were in the bed with the seats down though.
Here is the stock P700 air spring. Is it the same as a 1000?
7aeb7a27cf06bbbffdf9b070c2411475
It's 670N which is 150lb of force. I can't find the part number though when searching google. It must be a special made for Honda.
1778bc98239d2719d7919b3e1cc7980d
322,690
I'm pretty sure my 1000 had two? I'll look
66,869
Here is the 1000. It's a Single shock.
900 lb my foot!
9b9c6e81a7f13aa6b644b230e8a68126
I might have 5 lb of stuff in the back. It want self dump. It will even float part bump for me to take a picture.
1bcc5bb2d279e594f3e85bd1cf228f3d
900 lb my foot!
That one is 202lb of force. It would be a good upgrade for the P700 if they have the same dimensions.
66,869
Oh.. 200lb. Not 9.. lol.
Well. I agree with the OP.
It sucks!
It's in Newtons and must be converted for me to understand it.
900 newtons = 202 lb
272,140
It sucks!
What is the retracted length nd the length of the stroke of that gas cylinder? I know they make some small hydraulic cylinders 1" diameter that lift 1000 pounds quickly using only a 12v hydraulic pump. much much faster than an electric screw drive.
Here is the longest 19.5" with a 14" stroke for $86:
Welded Swivel Mount - Hydraulic Cylinders - Dalton Hydraulic
Here is the shortest 11.25long with a 4" stroke for $75:
These can be had in 2" increments for stroke and length, I am sure one could be retrofitted with a small hydraulic pump for those that would use a dump beds repeatedly daily: Dump Feed, Landscaping, gravel, firewood, mother in laws, etc.
272,140
Hold on there now I have ate my share of fig newtons and 900 of them are only about 26 pounds. :D
202 lbs. of fig newtons are about 6,500. Yeah I have waaay too much time on my hands. But at least I'm well fed :p
Reactions: joeymt33
McMaster Carr has a nice selection and decent prices.
6e5727537e7f93f089f51ff010b0981c
Reactions: ohanacreek
