P500 Easy way to mount winch to Strongmade Bumper?
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
The Superwinch came yesterday, and started looking at mounting it to my Strongmade bumper. I thought this part of the install would be the easiest. :rolleyes: The front two bolts look like they may be a b**** to access to get started and tighten. Also, bolts seem slightly short. Anyone figure out the "easy" way?
It was a PITA but lumber through and you'll get it. I had to buy 1-1/2" hardened stainless bolts. I found the 1-1/4's supplied a tad short.
267,204
Longer bolts makes all the difference in the world. Covered this in my P500 build thread. Good luck if you have big hands.
Reactions: FuzzyGrub
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
I looked at removing bumper, but that won't help. This is basically a winch mount with a slide over bumper. Was also considering a stud in the fronts, loctited in, but finding a hardened one locally would probably be an issue. Looks like it is longer bolts and some frustration. ;)
It was a pain.. but like they said little longer bolts and I used a ratchet wrench.
