Mine reads battery voltage while im charging anything from it
I've seen them but the true battery system came with two round volt meters. one for each battery.Have you thought about running the switch sized usb charger with a voltmeter built into it? I dont have a pic but others have posted pics on here of them.
Decided to use #1, but only half so I could put my cell holder on the other half.SOME IDEAS ON SWITCH PANEL View attachment 35571
I don't see much of a point in venting the radiator!!Did all my vent lines other then the rad. Fan motor. How important is that? Got the lights hooked up.
View attachment 36304 View attachment 36305
Also got the best upgrade done to date. Thanks for the stickers. View attachment 36306 View attachment 36307
Its a vent for the electric fan for the radiatorMaybe I'm not following.. so is this a vent for the radiator fan or the radiator coolant? Maybe I haven't looked at it closely enough.. but in my mind it was just the overflow for the coolant that was being vented. If we're talking venting the coolant.. it should be pressurized and not allow back flow.
I don't know what you're talking about regarding the fan vent??
I've never heard of such.. wtf kinda space craft did I buy!! Long gone are the days of simple s*** that just works!!Its a vent for the electric fan for the radiator
I like high range in sport mode..Went for the first ride this past Sunday. We did about 55 miles. It took me a little bit to figure out when to use low and high range. Low seams to shift up and down a lot at times. The last 10 mile or so I used manual and shifted up as I needed and let it shift down when it needed. That seamed to be at lot smoother. In high at times you could hardly here it changing gears. It seams to get smoother the more I run it. I noticed the heat only when riding in slow section. It was in the 30's and 40's so the heat was welcomed. All an all I loved riding it. Only thing that bothers me is my leg hurt trying to give it gas for long sections. Don't know how to fix that unless I add hand throttle. Witch would be a cool idea. Just don't know how to do that. I know there are handicap systems out there.
Anybody have any ideas? Anyway here are some pic's will try to get more from my son. He took most of the pic's and videos.
View attachment 37724 View attachment 37725 View attachment 37726
I like sport mode also. I like having 6 gears, just don't like it changing all the time.I like high range in sport mode..
I don't notice high sport auto shifting too much.. it's just about right really.. i did notice low constantly shifting though. High sport with the slap of a paddle shift occasionally when goingnup or down grade seems to be the sweet spot for my style of riding.I like sport mode also. I like having 6 gears, just don't like it changing all the time.
Yeah, sorry I didn't explain my self very well. That's what I was trying to say. sport mode don't shift as often as the others.I don't notice high sport auto shifting too much.. it's just about right really.. i did notice low constantly shifting though. High sport with the slap of a paddle shift occasionally when goingnup or down grade seems to be the sweet spot for my style of riding.
Hey! You got a video loaded!!!!Last Sunday ride. Very step and long down hill.
