P1000 Electrical Help
Johnny_C
Johnny_C
303
143
Western N. Carolina
The only problem I found was that I can't
hinge the filter cover over enough to get
the filter out. I will have to remove the
whole cover, but that's easy enough.
John
tjoreo
tjoreo
1,032
1,992
Southern Idaho
I have decided to use the Universal bus/relay shown earlier in this thread. I see that both nbomar and CumminsPusher have placed the in the same location.
Have you guys found any advantages or disadvantages to that location
? Has anyone with that same piece of equipment chosen a different mounting place?
I am just about to start drilling holes,screwing things down and running wire, so I thought I would ask where others have installed this unit?
I think if you look at Jackal's P1000-5 build he found a very interesting spot.
Blackstone
30
12
I have 2 questions,
1. What gauge wire are you running to your switches?
2. If you have a relay between batteries, does that mean the 2nd battery will not assist in starting the machine?
Thanks
283,012
I have 2 questions,
Thanks
1. Running 14 gauge wire to my 5 switches powered on by ignition that control the relays, as well as grounds for all and for the backlighted led's in the switches powered on when OEM lights are turned on. For the 5 switches using only the 15 amp fuse without relays using 12 gauge wire.
2. It's not a relay between the batteries it is an isolator. To answer the question no the second battery it not used to start but the isolator does allow it to charge when running. The purpose of the isolator it the prevent anything from draining the main battery while all accessories are ran off the second battery ie radio etc.
Blackstone
30
12
Thank you for clarifying this for me. I appreciate it!
Johnny_C
Johnny_C
303
143
Western N. Carolina
Is this the correct diagram for the
Bussmann Fuse Box?
Eeotg
Johnny_C
Johnny_C
303
143
Western N. Carolina
I am getting ready to order my switches from
OTTR, so that will be complete.
My next question is how many amps to do the
winch & aux battery solenoids pull? Do I need
to run them with a fused circuit, or can I wire
the power straight to them?
Thanks!
John
ghost
ghost
993
1,874
BC
If you are talking about the circuit to activate the coil in the winch solenoid, it probably pulls less than 1 amp so you can use a fused line. No need for a relay.
Do not attempt to run the winch power thru the PDM or anything other than the solenoid that come with the winch - It will fry.
Aux battery solenoid - is that instead of an isolator? Any solenoid coil should be fine with a fused circuit. Same warning as above about the high power output of the solenoid.
Johnny_C
Johnny_C
303
143
Western N. Carolina
Yes.
"Isolator" for the aux battery.
But I am talking about switching power,
not full amp working power.
Thanks!
John
winnscollision
winnscollision
92
51
Saluda SC
Damned all these wires!! Winch installed and had to top spool! Mounted my bussman above my aux battery.
Reactions: ghost
ghost
ghost
993
1,874
BC
Yeah John - I figured you were on top of that. I guess I put my warning in there for any newbies that might be reading this.
winnscollision - good thinking on the bussman location. I know what you mean about the nest of wires.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
For those that dont like the glove box mount for the winch controller, I mounted mine on the black plastic between the hood and windshield. Offcenter to the driverside so i can reach out and plug in the controller from the drivers seat or stand outside the vehicle and run the controller. The cap on the receptacle closes up tight so shouldnt be any contamination issues.
ghost
ghost
993
1,874
BC
Here's another spot to mount the PDM.
Remove the metal mounts that came with it and drill a small hole to put the wires thru.
I cut off the bottom of two 30-06 cases to use as spacers. I think I deserve extra red neck credits for that :D
IMG 2177 1 IMG 2179 1 IMG 2180
BigRiver
BigRiver
324
79
Here's a pic of my layout. I took quite a few steps back and forth before I was satisfied with the position and configuration of it all.
The fuses on either side of the isolator were a challenge, not much cable length to include the fuses.
BA4DAED5 378C 4147 8067 A09D95597410
How was setup on the PDM60?
BigRiver
BigRiver
324
79
Not bad at all, even for a novice such as myself. The 6 circuit lines are all color coded and identified by number. One of the installation instruction sheets identifies each circuit line with its amperage capability. These circuit amperages of 5, 10 and 15 amps can be reshuffled so to speak via connection to a computer, but I was fine with the layout provided. One can choose between a ignition activation or a ground activation, I chose the ignition.
I like the feature of not depending on various fuses, should ever a circuit fail, just identify the problem on the circuit via the lights on the module, correct the issue, and cycle the key on and off, the PDM resets the circuit.
On very minor thing I've noticed, and I'm completely fine with this, once the key is turned on, it takes 7 seconds for the PDM to cycle up.
If I were ever doing this again, I'd definitely go with this PDM. Thanks for the suggestion Ohanacreek!
Reactions: ohanacreek
