P1000 Electrical Question P1K5LE
daryladams
daryladams
6
9
Nashoba, OK
I'm in a dual battery situation. Can I wire the winch to the backup battery, and wire the winch rocker switch to the "keyed on" power via the primary battery? I want to avoid the LED in the rocker switch running the battery down over time. Thanks.
Reactions: Isaiah
Vikes79
Vikes79
SKOL!
11,709
113,613
South Dakota
  2. Talon X4 LV
What I did was setup a fuse block on the second battery that is activated by a 60amp key on relay. My winch dash switch is on this fuse block. The winch remote connection I left direct to the second battery.
66,870
Yes, This is recommended.
Winch, both + and - primary wires to the second battery.
The small red wire is hooked to a key-on source for safety reasons.
