![daryladams](/data/avatars/m/11/11856.jpg?1592868937)
I'm in a dual battery situation. Can I wire the winch to the backup battery, and wire the winch rocker switch to the "keyed on" power via the primary battery? I want to avoid the LED in the rocker switch running the battery down over time. Thanks.
Yes, This is recommended.I'm in a dual battery situation. Can I wire the winch to the backup battery, and wire the winch rocker switch to the "keyed on" power via the primary battery? I want to avoid the LED in the rocker switch running the battery down over time. Thanks.
