P1000m5 Engine Overheat
ReillyFarrel
ReillyFarrel
22
16
Labrador, Canada
Hey guys, I was plowing my driveway today and my engine temperature spiked up to max.. i shut the machine down and the coolant was bubbling inside the reservoir and heavy flowing out of the overflow... any ideas?
Reactions: JenElio and TxDoc
JenElio
JenElio
73,377
667,448
Loxahatchee, florida
Was the fan running?
When mine overheated it was due to a small clump of dried up mud enabling the fan from spinning. In your case it might be a chunk of ice 🤷‍♂️
Reactions: Mudwing
ReillyFarrel
ReillyFarrel
22
16
Labrador, Canada
Fan is running yes!
tdhanses
tdhanses
1,044
3,553
Kansas
Did you recently add a heater?
TripleB
TripleB
15,251
136,271
Caryville, Tennessee
Fan is running yes!
But was the fan running when it overheated? If you cycled the key, the fan would probably come on making u think nothing is wrong with the fan. I overheated 1 time due to this problem. I had like 1100 miles on it before I ever happened.
ReillyFarrel
ReillyFarrel
22
16
Labrador, Canada
I wouldn’t be able to say for sure if it was running, i’m running around the 1400 Kilometre mark right now..
I am going to top up the coolant tomorrow and try to simulate the problem again.
Reactions: TripleB
TripleB
TripleB
15,251
136,271
I've not had mine updated for the fan either. It's some kinda glitch. I read 2 years ago that if you don't pause with key and just go straight to starting the machine, the fan will come on like its supposed to. I've made sure I've done that ever since and I've not had a problem since. I'm at 7000 miles now. My friend has the same machine. I told him about not pausing a couple different times. 1 day on a ride with him, I watched him pause and then start. I never said anything cause I didn't wanna sound like his daddy. About 4 miles down the trail and he was boiling over because the fan wasn't running. He not had it happen since. It won't do it every time u pause. Sometime in 2019 they came out with a fix. Good luck.
JenElio
JenElio
73,377
667,448
Make sure you burp it before topping off, otherwise you'll have a air pocket in the lines.
ReillyFarrel
ReillyFarrel
22
16
Labrador, Canada
I’ll keep this in mind from now on, thanks!
ReillyFarrel
ReillyFarrel
22
16
Labrador, Canada
6bae2386bd14ed2f1604cb5d1d0aa70aWould this be ok to use as replacement coolant?
