Engine shuts off from start and stop occasionally
L
leclaza169
25
Phoenix
  1. Talon X4 LV
The video it does it like 5 times before i zoom in on the clutch temp light that also flashed
Reactions: ChadD
HondaTech
Which engine ground ? And any ideas on what to do about the relearn not working and leaving my at and mt lights on?
Did the dash start blinking fast or did a "U" show on the dash when performing the relearn? It can be driven arouns just fine with the AT/MT on. But it should take a relearn once the issue your having is repaired.
The ground that stripped on the Pioneers was the one next to the starter on the block itself. You couldnt wiggle it with your hand, but if you put a wrench or socket on the bolt it wouldn't tighten up.
Id check the ground on the frame and the ground under the seat as well. Make sure the ones under the seat and on the frame tube are down to bare metal.
Reactions: ChadD
L
leclaza169
25
Phoenix
  1. Talon X4 LV
The one at the back of the engine on the farm is on bare metal checked that one i will check under the seat also and no i just got the flashing dash symbol but never went blank
L
leclaza169
25
Phoenix
  1. Talon X4 LV
The one on the block is it easy to access ?
HondaTech
Its right next the starter motor. If your looking at the Drivers side if the engine, it'll be easy to spot.
The next time the unit dies, check the dash for a flashing code, that'll help narrow it down possibly
L
leclaza169
25
Phoenix
  1. Talon X4 LV
I never get a flashing code or anything and it starts right back up
5,758
26,443
Does this work ?
Yes, I was able to watch it. But I have a Google account and it logged me in automatically. That may not work for others.
Not sure about your phone but the dash is landscape so hold your phone landscape. Some phones seem to post portrait orientated videos no matter how you hold them.
Reactions: leclaza169
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
Does this work ?
The flashing light is meaningless. It is the blinking "dash" in the gear indicator that we need to see. Hold the camera still on the entire dash and turn the key on for at least 30 seconds so we can see the entire dash and read it for you. We need to see the gear indicator AND the drive mode.
L
leclaza169
25
Phoenix
  1. Talon X4 LV
It stayed a blinking dash mark it blinked multiple times never did anything else
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
That blinking is usually code. If you do as I asked and record 30 seconds worth, maybe we can help you decipher it.
Otherwise, you will have to take it to your dealer and have them hook up their fancy machine.
HondaTech
It was blinking long flashes, which is the start of a code.
If it blinks immediately with the key turned on, count the number of long (2 second) and short (1 second) flashes.
It'll pause then repeat the code of flash another if there are multiple current codes.
Or if its not flashing until it dies, then count those flashes.
The clutch light means nothing.
L
leclaza169
25
Phoenix
  1. Talon X4 LV
i see what yall are saying i will try today and if it shuts off i will take a video of the dash and will post it here.
Reactions: CID
L
leclaza169
25
Phoenix
  1. Talon X4 LV
best part is its been to the shop 5 times in the last two months and that fancy machine aint doing nothing lol
  • Sad
Reactions: CID
L
leclaza169
25
Phoenix
  1. Talon X4 LV
I cannot get the talon to go through the relearn at all continue to get to the quick flashing dash and never goes through full process
HondaTech
Most likely whats causing the stalling issue is keeping it from being happy while its performing the relearn.
