Engine shuts off from start and stop occasionally
L
leclaza169
25
Phoenix
  1. Talon X4 LV
Hello all i am new to the group and have had my talon for a little over a year. I have about 3,000 miles and have been having an issue with the car shutting off when giving it a little gas to go and sometimes coming to a full stop. Things done. Oil and fluids all changed. Had the battery connections replaced, i also had the valves readjusted and new spark plugs placed in the car. The next thing is the recall on the intake boot and the bolts. But continues to do it all throughout all of the work that has been done on the car. Wondering if anyone has done anything else or experienced anything like this. No engine lights nothing that stands out and the car will start right back up after it shuts off.
Reactions: ChadD
L
leclaza169
25
Phoenix
  1. Talon X4 LV
Have you tried doing a clutch relearn procedure?
i have not i pick it up today and thought about trying that next do you by any chance have the directions for the 2020 honda talon x4
Reactions: ChadD
SLOWPOKE693
SLOWPOKE693
1,861
7,350
Somewhere in Texas
I don't off hand, but I think I know a guy that can link you to it. @CID would be the guy that can help you with that.
Out of curiosity, who is doing the work on your Talon?
Reactions: Fritz-NH and ChadD
5,484
25,244
Here you go. There's more basic Talon information linked in my sig.
Post #27. It shows a Pioneer 1000 but the procedure is the same.
Thanks for the tag. 👍
L
leclaza169
25
Phoenix
  1. Talon X4 LV
it has been to ride now 5 times in the last 2 months. And now is at direct utv here in az
Reactions: ChadD
L
leclaza169
25
Phoenix
  1. Talon X4 LV
will try this once i get it home
Reactions: ChadD and CID
L
leclaza169
25
Phoenix
  1. Talon X4 LV
Is it a common issue to have to do the relearn when nothing clutch work wise has been done?
Reactions: ChadD
5,484
25,244
A relearn should be done regularly, I'm thinkin' at every oil change or every 2000 miles (not the same). Pick something that works for you.
hondatalonr
38
53
Arizona
My question is what is meant by shutting off. If the engine is shutting off how would that have any thing to do with the clutch?
L
leclaza169
25
Phoenix
  1. Talon X4 LV
Make sure it's fully warmed up first.
So warmed it up followed video had two notches on the temp. Never got rid of the dash blinking now mt and at light stay on any ideas on what to do next? Or did i mess something up?
Reactions: ChadD
5,484
25,244
@HondaTech any tips?
Reactions: ChadD
HondaTech
When it dies, leave the key on and watch the dash. Count the gear indicator flashes.
Its almost acting like the Pioneers when the engine ground bolt is stripped.
Reactions: ChadD
L
leclaza169
25
Phoenix
  1. Talon X4 LV
Which engine ground ? And any ideas on what to do about the relearn not working and leaving my at and mt lights on?
Reactions: ChadD
