P500 Exhaust is on the way
ehart814
ehart814
1,655
3,645
NWPA
I've really been itching for an exhaust since riding this past weekend. The 2 rhino's had aftermarket exhausts and they sounded awesome.
Ideally, I would have an exhaust that can be easily and quickly swapped back to the quiet OEM exhaust for when hunting season comes around.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
most aftermarket exhausts u can buy a quiet core insert to add on later to quiet them down
Reactions: ehart814
sthomp54
sthomp54
375
Which exhaust did you get? I am assuming you will have to weld it on? Did you get the fuel tuner too?
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
im not spilling the beans yet and yes ill have to mod it and weld and no tuner yet im going to see if the stock efi and compensate for the extra air flow i took some afr readings and they are pretty good not running lean but even if it can i plan on a tuner in the near future
Reactions: ehart814
ehart814
ehart814
1,655
3,645
NWPA
This thread is exciting....
Can't wait to hear about @jak9922 's P500 with a little more throttle response and "kick"
Hopefully the Dobeck, or Power Commander will be added too. I am confident it will be excessively lean without using a tuner to richen it up.
ehart814
ehart814
1,655
3,645
NWPA
that is really surprising to me about the afr readings. When I pulled my plug out it was very white.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
my autometer afr only went lean on first off throttle then leveled back out mod 14s with is perfect full throttle was just under 14
Reactions: ehart814
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
im going to use the dobeck afr system for sure ive had nothing but great experience with thier products
Reactions: ehart814
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
I know it's already ordered, but if it was me I'd try to retrofit a muffler for a CRF 450. Then you'd have all of the inserts available, like quiet core, spark arrester, etc. be cool to see how this works out.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
i have a set off a cbr600 was gonna make duals but shocks kinda took up that area lol
182,443
just ordered an exhaust for it ill give more details the same way as I did with the shocks ;)
Very cool Jak. I've seen your vids on youtube, try to get us some good sound of before and after. No need for me to tackle your shock mod but this one has peaked my interest.
Reactions: jak9922
Speaking of spark arrester, do you know if the P-5 has that from the factory?
Yes they come with it. Required for public trails.
Yeah, I know they're required, which was why I asked. Glad it's not something I have to add. Thanks trigger.
Reactions: trigger
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
boom hmf for a 2011 foreman
20160518 160317
