P1000 Exhaust Tip
Justinp1-5
Justinp1-5
56
70
Central florida
May not be the place to ask, but is there a trick to getting the tip off? Just broke the first bolt and can't replace it at this exact moment. Should I heat the exhaust up first or are they just gonna break on me
Reactions: Papaandhistoys
Mopower58
Mopower58
Unburdened by what has been!
87,619
751,891
Crystal Springs,Ms.
I would definitely heat it up first. I did mine 2 or 3 years ago and the machine was fairly new so all 3 came out fairly easily. I just ordered a stainless elbow, took it to a friend's fabricating shop, he cut off the old tip and welded on the new one. I used never seize on the bolts when I put them back in.
IMG 0211
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Need to be cold a constant slow pressure against the bolt They probly was put in to tight . If they're rusted you might put some wd 40 on them and let them soak before removing them.
Reactions: Isaiah
Mopower58
Mopower58
87,619
751,891
Crystal Springs,Ms.
The bolts usually gald and damage the threads, no one I know uses ice to remove a damaged bolt. Heat expands the female threads and allows for easier removal. Like I said before, use antiseize on bolt installation, makes for easier removal next time.
