P700 EZSteer power steering missing wiring harness
E
ericm
15
Santa Cruz Mountains, California
I installed the EZsteer kit today on my 700P2. It's missing the last part of wiring harness that goes back to the battery under the seat. The power harness is only about 2' long and ends with a ring terminal for ground, male bullet connector on the + lead, and a two pin square plug on the white switched power lead. That one doesn't match anything I can find under the hood.
Anyone else have this happen?
Reactions: Tramguage1
bigbruse
88
37
va
how hard was the install? looking to buy this upgrade myself
allgm1
allgm1
1,049
1,484
New Hampshire
white wire gets spliced into a switched 12v source, the instructions on-line show the white wire getting a blue scotch lock connector to connect it I'm not sure why yours has a connector on it. As long as you have the plugs that go into the control box you should be able to make it work.
Reactions: Tflynn
tjoreo
tjoreo
1,011
1,929
Southern Idaho
It sounds like they have made a mistake for sure. Mine had the long wire harness to reach under the seat with BOTH wires having ring terminals on it. The white wire didn't have a terminal on it. If you look at the instructions on page 2. Fig J is showing a short wire, while towards the end it shows the whole harness. So somehow they must have sent the short wire harness. On mine I had wire running from the battery to my winch contactor under the hood so I just hooked on there. That might be an option for you. Definitely don't get too disappointed because this is the definitely one of the best accessories yet. http://www.superatv.com/instructions/IN-PS-3-37.pdf
Reactions: Tflynn
tjoreo
tjoreo
1,011
1,929
Southern Idaho
It was a fairly straight forward install and definitely worth the money. With my wife's help it took me about 45 minutes to put it on. I didn't remove anything (dash, fender, c clip), just removed the hood. If you do it this way it definitely helps having the extra person. Like I said above I just hooked the wires under the hood to my winch contactor, so running back to the battery would of took a little more time. Good luck. And if you enter the coupon code "Hondaforum" it will save a little money on superatv website.
Reactions: bigbruse
7,148
27,219
is you kit the one from EZ Steer? Is it the correct kit for the Honda?
E
ericm
15
45 minutes! It took me most of a day. I've been working on cars and motorcycles for 40 years. I do take my time and try to be careful.
I removed the door, side panel and fender. Had to unfasten the dash and pull it up in order to remove the fender. I could not get the shift knobs off but with them on I could pull the dash up enough to get to the fender bolts under it. Pulling the dash up makes it easier to get to the C clip on the steering shaft.
My part J wiring harness is about 3' like I described above. I'll call SuperATV tomorrow.
I ordered it from Amazon. Perhaps I should have gotten it direct from SuperATV.
It's not in the instructions but there's a removeable panel behind the radiator that directs air downwards. It attaches to the cross bar that the PS motor mounts on, using some push pins at the top and tabs at the bottom that fit into holes. You have to remove it to fit the motor mount. But with some trimming it can be put back on. It'd be best to fit it before fitting the motor mount. If you try to fit it afterwards you'll have to trim more off to get it in.
7,148
27,219
I left that panel out after install. but after the first test drive I trimmed it and reinstalled it.
Lynn1130
Lynn1130
126
171
Phoenix, AZ
Call the company that you order it from and let them know you are missing a part. They will ship it to you at no cost, or should.
There are several threads on install of the power steering that can help. Some have done the full removal route and some just the minimum. I did not remove the dash but did remove the fender. It was easier getting to the steering linkage that way.
LandPioneer
LandPioneer
929
2,417
Lebanon TN
It took me about 2hrs to install mine with no help. I only removed the left front fender. It wasn't a very difficult install and works great. I highly recommend getting power steering if you don't have it.
ckhenshaw4
176
81
My father in law and I installed mine. I only removed the hood and drivers fender. You don't have to remove the C clip to do the job. Took us a little more than a couple hours, but well worth it. I have a BOSS V plow on mine, and the power steering makes it a breeze to steer now.
Sent from my Nexus 7 using Tapatalk
E
ericm
15
I messaged the vendor on Amazon and they shipped the correct harness last Monday. It arrived today and I installed it this evening. Steering is much lighter now. Backing it out of the garage and down to the barn at night made me realize that there's no reverse lights. I'll need to put in a rear work light. And a windscreen and mirrors.
