P1000 Falling washers?
Formula1
Formula1
160
264
SE Missouri
I removed my seat back tonight along with the plastic piece and the rubber mats in preparation to install my cooling fans. As I was removing one of the push pins holding on the plastic engine cover piece, two washers fell out. Any idea why they were there?
Reactions: DG Rider
ToddACimer
ToddACimer
Pioneer 1005-2
3,568
14,655
Oshkosh, Wi
The metal bracket added to support the rubber seat heat shield has 2 washers on the pins through the bracket and rubber. They are a pain to install
Formula1
Formula1
160
264
SE Missouri
Oh great! I looked through the service manual and it doesn't mention them. Any idea if there totally necessary?
ToddACimer
ToddACimer
Pioneer 1005-2
3,568
14,655
Oshkosh, Wi
I'd try to put them back. The bracket won't stay on without
Formula1
Formula1
160
264
SE Missouri
So does the bracket fall also? I'm not sure what exactly I'm looking for.
Formula1
Formula1
160
264
SE Missouri
I found it, it fell as well. Now I just gotta figure out where it goes
sek-hunter
sek-hunter
306
574
Between driver and middle seat. Look for a parts diagram. Seems like there are three plastic rivets that hold it in? I’ll look...
sek-hunter
sek-hunter
306
574
Found it but won’t let me post here.
hondapartshouse.com has the diagram
sek-hunter
sek-hunter
306
574
Look at the seat bottom cover diagram.
Formula1
Formula1
160
264
SE Missouri
Awesome thanks! Does it go between the frame and the cover of the air box?
TripleB
TripleB
11,984
101,898
Caryville, Tennessee
MjAzMDk1MA 001db827
#15
