William
My fan isn’t working now. Got all the way on the temp gauge. Y’all think it’s the motor? Never deep water to get in it...
And.Fuse good?
Try unplugging the connector and applying power to in directly.
Well. That sucks.Ok I checked the fuse, voltage on blue wire, and hooked the fan up to direct power. It’s the fan motor.... Now I got to figure out how the heck to get it out!!!
Theres a height specification for the fan vent, I think its 31 inches off the ground. You would've had it pretty deep to get that in water.
Edit: The vent hose should be around 31 inches off the ground, around the middle of the fan motor, maybe just a little higher. Youd know if you had it that deep.
I did it without pulling the grille off... Was easy.Pain in the butt. Got to rip the whole front end apart.
