I've had some feed back on camber adjust from another post but I would like more. I've been told I need both adjustable a-arms and preload adjustable shocks. I been told to get shocks first, I've been told to get a-arms first. I don't want to spend money on either but my inside tire wear is bad. The machine is heavy on the with a full cab, big heavy bumper, heavy winch, etc. I'd just like to get as much feed back before I have to drop some major coin to fix this problem. The first picture is before I noticed the tire wear the second is after. Also, about the second picture of the tire wear. The toe was way out and I adjusted it but it's to late for the tires. I just mounted a set of the same front tire I had in the garage that were 3/4's of the way wore out. Mounted them today and I'm going to be watching to see how much, if any, the toe adjustment helps.
