P500 First Air Cleaner Service
bms
bms
66
135
Pa
I cleaned my air filter for the first time Sunday. Mind you I'm a teacher, not a mechanic, and after looking here on the forums, I wasn't sure what to clean it with, since not one gas station in my area sells kerosene! So, I ended up using hot water and dawn dishwashing and cleaned it as best as I could, changing the water a few times and making sure it was totally dry before oiling. Finally, I did use Uni spray-on foam filter oil, and that worked great.
What could be used to clean the filter besides kerosene? Thanks!
43,070
Gas. Kerosene. There are specific cleaners available as well.
I've had zero luck using dawn/soap and water, but I haven't used no toil or Honda oil either.
Reactions: Backwoods
5,429
24,926
I read here in past posts that gas is a no-no for foam air filters - is that true? Not they're that expensive to replace, but...
I used gas for decades on the dirt bikes, just don't soak the filter in it. I'd put 2" in a container, dip the filter repeatedly until it was clean and then use the air compressor to blow dry. I've since switched to kerosene (bought a 5 gallon container) and clean with Dawn original (blue), blow and paper towel dry and let sit overnight if I have the time. Then add enough oil that I can squeeze out the excess, assuring 100% coverage - I'd much rather it was over oiled than under oiled.
Depending on surface area, oiled foam is incredibly efficient, even when it looks like they're totally plugged. Many guys clean them way too soon.
Still working just fine at 1066 miles (first cleaning). The filter is bright red under the goop. :oops:
I KRxxBDV XL
Proof, stock filter behind the foam prefilter at 1137 miles - (Talons will total a stock filter at 200-300 miles)
I cC2r3Xx L
BURNDOG
BURNDOG
84
229
Oregon
I go old school. Because I’m old. Dish soap. Don’t matter the brand. Usually dawn. Wash it out really good. Let it dry. Cheap-o light weight motor oil. Squeeze out the excess with paper towels.
Been doing it that way for ever.
Usually once between oil changes.
And always keep a spare filter since they are so cheap.
43,070
Supposedly, but I have yet to see it. I dip it quickly and rinse it in Soapy water right away. And keep an eye on it. I usually replace them after a while anyway.
208,726
You can buy foam air cleaner spray, I use Dawn dishwashing soap.
43,070
I know. Gas is cheaper and seems to work better.
And works on all brands of oil, which is nice, since I've had "brand y" cleaner not work so well on "brand x" oil.
And Dawn may work on No Toil or something similar, but it won't do s*** for some of the really tacky oil brands. I know...I tried it (again) not to long ago. Maybe I'll start using No Toil just for that reason.
Backwoods
Backwoods
35,248
357,922
Douglasville ga
I use purple degreaser and Dawn. work it in real good and let soak for a couple of hours then rinse. I have more than one filter so there's always a clean one ready.
Hondap5
Hondap5
20
58
Monroe nc
New oem filter is 10-15$ at the local Honda shop. Comes in a Honda bag pre oiled. Almost to convenient
Reactions: bms and CID
BURNDOG
BURNDOG
84
229
Oregon
I used that “awesome orange” or this concentrated degreaser from the dollar store my last filter cleanings. Along with the dish soap...🤷‍♂️ and it cuts oil real nice for like a pretreat I guess. And it’s really cheap. Surprisingly it’s only one dollar.
Go figure......
Reactions: bms and pappyo
